I am finishing up a DIY center channel to (hopefully) match a pair of Klipsch Heresy I's. The woodworking has gone fine, now I have to address some crossover modifications.
In place of the Klipsch K-22 12.00-inch woofer I went with dual Dayton Classic II 8.00-inch in parallel. The SPL's worked out about equal. The cone areas are close. I do not know the specs for the K-22, but assume from the sensitivity and design it has lower inductance and nominal resistance than a single 8.00. Is it similar to an Eminence Kappa? Dunno, that's what I looked at. Eminence: 5.5 Ohm / 1.22 mH Dayton II: 8 Ohm / 1.56 mH each Attached is the Klipsch Type E crossover. The woofer circuit has a 2.5 mH inductor on it. I want the circuit to behave like it did. Question: Given dual 8.00's what should the new inductor value be? Considering parallel resistance and inductance, it seems I need to add inductance. However, I have read otherwise, that I should lower the inductance. ???. Then the is the question of the type of coil. I really could use some DC resistance, so I am considering an air-core coil, about .4 Ohm higher with 20 gague. ???. The Klipsch use laminated iron core design, just like an old transformer. Thanks for a reality check. jocko |
#2 |
given the Classic IIs sample resonse graph I'd consider adding a capacitor to go second order. http://www.partsexpress.com/pdf/295-100.pdf |
| Can you check this crossover repair job? | silentblackhat | Solid State | 0 | 10th November 2008 12:55 AM |
| Reality Check | jdlech | Multi-Way | 11 | 26th January 2008 05:55 AM |
| check my crossover | rv1890 | Multi-Way | 18 | 25th February 2006 09:35 AM |
| tube amp layout reality check | zobsky | Tubes / Valves | 5 | 10th August 2005 04:20 PM |
| Reality check | analog_sa | Chip Amps | 2 | 10th November 2003 09:30 PM |
| Page generated in 0.07587 seconds (69.18% PHP - 30.82% MySQL) with 11 queries |
