What effect will increasing the impedance of the loudspeaker have on the performance of the amplifier circuit it is run by?
For example a circuit designed to run an 8 ohm loadspeaker running a 16 ohm one instead. this is the circuit i plan to build. All i want to know is, will it work decently enough for it's purpose - driving a 16 ohm compression driver. |
#2 |
Generally an amplifier will give less than rated output for higher impedences. So you might get 4-5 watts out of this design into 16 ohms. Depending on the efficiency of the driver this may or may not be an issue.
| increasing Iq in Arcam Alpha 9 integrated amplifier | audiocrow | Solid State | 1 | 25th November 2009 06:39 PM |
| 60watt x 2 into 6 ohm load amplifier | fetchitfido | Everything Else | 3 | 19th December 2005 03:47 PM |
| 60watt x 2 into 6 ohm load amplifier | fetchitfido | Everything Else | 0 | 15th December 2005 09:33 PM |
| Increasing amplifier auto-turn on sensitivity. | DcibeL | Chip Amps | 14 | 26th November 2005 03:21 PM |
| Increasing Power Output of a Car amplifier | Dj BASS AMP | Solid State | 5 | 5th October 2002 11:37 PM |
| Page generated in 0.08173 seconds (71.35% PHP - 28.65% MySQL) with 10 queries |
