There was apparently a review of a Thiel coax driver called the SC3. If anyone has the measurements and info on this driver I would really appreciate it. Thanks |
#2 | |
#3 |
Yes I thought he did as well, but I thought others here may have it. Still waiting for a reply to my last email I sent Thorsten a few days ago!
#4 |
Digging around on here I did find:
Thiel coherent source drivers Seem Klang&Ton did a coax roundup and distortion wise the older model of Seas coax did better. I believe you have the newer version with an improved tweeter. One thing to remember though: harmonic distortion isn't the only distortion. There's a whole system of amplitude and time based errors/distortions in place that need to be carefully looked at. Take a look at the RAAL's for instance, average distortion figures at best but look at time based distortion and power compression, even the best domes look average here. |
#5 |
Well I do start to wonder when people just say 'lowest distortion driver we know of' and don't give figures.
I am very aware HD is not the only factor, having tried the Mangers! But I do think you have to look at all factors and work out what you are looking for. If you can get a driver that measures better in every department, so no trade off, then I do belive that equates to better sound. I find that CSD is equally as important as HD, but on the other hand I am never very bothered by efficiency as long as it doesn't make the drivers hard to match, like a lower sensitivity tweeter than woofer, I don't mind. You can see some distortion tests of the new Seas driver here - http://www.soundstageav.com/onhifi/20050901.htm I will post my build when I am done in a few days. As I said before, these are only as a point of reference. I wouldn't say RAAL HD is average at best, maybe for the cost, but it is all below 0.5% in the usable range. |
#6 |
Hi Tenson!
I have the review you're looking for. If you still need it, you can send me a PM. Regards, Milan |
#7 |
Hi Milan, I sent you an email. Cheers!
#8 |
Hi Simon!
I've just sent you the file. I'm sorry it took me a while. I had to scan the papers first. Regards, Milan |
| Empire 2004 cartridge info | percy | Analogue Source | 5 | 9th October 2011 10:10 PM |
| driver id./info for Isophon/Philips/Fisher(Marsland?) | Kazik | Multi-Way | 1 | 11th March 2007 03:45 AM |
| Ported Enclosure Design w/o Driver Theil-Small Parameters | misterbobman | Multi-Way | 6 | 29th March 2005 02:06 PM |
| Searching for old driver info.. | DigitalJunkie | Multi-Way | 6 | 10th November 2004 03:10 PM |
| newbie question theil small | psychosteve | Multi-Way | 9 | 1st October 2004 03:18 PM |
| Page generated in 0.09395 seconds (76.52% PHP - 23.48% MySQL) with 10 queries |
