Old 2nd February 2007, 09:38 PM   #1
wixy is offline wixy  Australia
Default What glue to use?
I'm about to start building these speakers out of mdf: http://www.fostexinternational.com/d...ez_enclrev.pdf
What type of glue should I use, or is any wood glue ok?
Would I need to use any screws?
Is it necessary to use some sort of sealent between the joints inside the cabinet?
Old 2nd February 2007, 09:42 PM   #2
Speakerholic
Cal Weldon's Avatar
Default Re: What glue to use?
Any wood glue is fine. I use the yellow stuff but white is fine.
[i]Would I need to use any screws?[/B]
It depends on how many clamps you have.
[i]Is it necessary to use some sort of sealent between the joints inside the cabinet? [/B]
Not if you use lots of glue.
This is your first go at it?
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 2nd February 2007, 09:44 PM   #3
Yep, first go. Thanks for the advice. I plan on getting some clamps and doing it all in stages, so I guess that means I won't need any screws?
Old 3rd February 2007, 12:20 AM   #4
Speakerholic
Cal Weldon's Avatar
My personal favourite is inside corner blocking and a brad nailer so all but the back of the cabinets have concealed fasteners. No clamps required and fast assembly once the blocks are in place.
Your way is fine if you don't mind waiting. No screws required.
Old 3rd February 2007, 12:55 AM   #5
TerryO is offline TerryO  United States
TerryO's Avatar
I have to agree with Cal on the use of cleats, it's as basic as can be and produces a strong cabinet. I've used nails, screws, clamps, straps, etc., and yet cleats and brads work just as well or better. It's pretty fast, which when you're using carpenter's glue is a factor that should be given a fair amount of consideration.
I like yellow glue best for MDF or ply and Weldwood for dark hardwoods. Weldwood is strong, but needs tight joints. I've used it for boatbuilding and the one criticism I heard for that application is that it isn't water proof because it won't hold if boiled. The late Capt. Pete Culler, boat designer and builder advised: "If you plan on boiling your boat don't use it!"
Seriously, Yellow glue is more than strong enough to preclude any further consideration.
Best Regards,
TerryO
"If you have to ask why, then you're probably on the right track."
quote from Terry Olson's DIYaudio Forum application
Old 3rd February 2007, 03:51 AM   #6
I think I will give yellow glue a shot, thanks guys!
Old 3rd February 2007, 04:09 AM   #7
diyAudio Moderator Emeritus
roddyama's Avatar
If you do decide to use screws (I do), be sure to use a countersinking drill for each screw. MFD has a tendency to split when you try to force a screw or nail in where there isn't a pilot hole.
Rodd Yamashita
Old 3rd February 2007, 08:22 AM   #8
frugal-phile(tm)
planet10's Avatar
mdf 208ez_enclrev
Fostex -- and many namy people that have built these in mdf -- recommend that you use plywood.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 3rd February 2007, 10:14 AM   #9
Geoff H is offline Geoff H  Australia
Slightly off topic, but I think worth noting. MDF (in this country anyway) seems to be non-consistent in density. I have noticed this on the jigsaw, panel saw, and drilling.
If you can, use a good quality outdoor grade ply.
Cleats not only make a stronger joint as others have pointed out, will provide more surface area to seal and make the joints air-tight.
I don't know what's in MDF, but I have noticed special glue (PVA type) and primer labelled for MDF.
FWIW I screw and glue. Too impatient for clamps.
Geoff.
Old 3rd February 2007, 02:17 PM   #10
Speakerholic
Cal Weldon's Avatar
I use brads and blocks. Too impatient for screws and glue.
What glue to use feverdog873 Multi-Way 17 5th January 2009 11:46 PM
Gel glue loninappleton Full Range 18 29th December 2007 01:03 AM
glue up : thickness then_dude Multi-Way 3 27th July 2006 03:37 AM
conductivity of hot glue? Dominick22 Chip Amps 4 20th June 2006 04:18 AM
Glue like (better than ) RTV........ ashok Everything Else 8 5th June 2004 12:40 PM
Page generated in 0.13060 seconds (78.15% PHP - 21.85% MySQL) with 11 queries
