Hello,
I design my loudspeakers with Morel Supreme 110 tweeter. I use with Skaaning 18H52 midwoofer. I read that the mdt33 is better from the sup.110, somebody try it? My question is if I can move to MDT 33 tweeter whitout tune the crossover that I have? I buy very expensive resistors and cap in this planet for the supreme and I don't want buy a new one. Morel indicate efficiency of 91.5 dB for the 110 and 92.5 for the mdt33. but on the curved they exhibit is very close to each other... Somebody try it? Is clever for change the supreme 110 to mdt33? (I cross around 2200Hz and use with first order) Thank you very much. |
#2 |
Please friends...
I can use with MDT33 without change the crossover? |
#3 |
Do you have an impedance compensation circuit? The peak impedance of the MDT33 appears to be slightly higher in frequency, and a couple of ohms lower than that of the Supreme.
Neither tweeter, in my opinion, seems to be well suited to a first order crossover at 2.2khz, due to the 800 hz resonance frequency. It might sound OK at low listening volumes, but it will start to distort if they are made to play loudly. You will get far better sound if you use cheaper resistors, capacitors, and inductors (air core, not iron), and a properly designed crossover. |
| can someone identify these morel tweeters? | terry j | Multi-Way | 2 | 27th May 2009 12:10 PM |
| FS: Pair of Morel MDT-33 tweeters. | Wanderer | Swap Meet | 4 | 23rd March 2007 07:20 PM |
| FS: Morel/Renaissance tweeters | MarkHathaway | Swap Meet | 0 | 22nd January 2006 06:38 AM |
| Opinions on Morel tweeters | wintermute | Multi-Way | 18 | 10th August 2003 02:27 AM |
| FS or Trade: Morel MDT 57.04 tweeters | feke67 | Swap Meet | 1 | 18th June 2002 10:35 PM |
| Page generated in 0.06986 seconds (71.67% PHP - 28.33% MySQL) with 10 queries |
