Floorstanding speaker Option 1: Focal Audiom TD5 Focal 6WM Focal 11WX Option 2: SS D2905-990000 SS15M4531K00 2x SS 18W8531G00 Both are about the same in parts. I suppose the choice is, do I want a JM Lab Utopia clone or a Sonus Faber clone???? |
#2 |
Focal drivers are generally inferior to Scan Speak drivers.
I've taken a few Focal motors apart and their design is nothing special which is reflected in their lackluster performance. For Scan Speak tweeters, I'd use a 6600 Aircirc if you can get one.
-Zaph|Audio- |
#3 |
If you choose Scan-Speak, here is what you need - a French link to a Cremona clone containing enclosures and crossovers.
http://www.homecinema-fr.com/forum/v...faa43be2bb66f2 By the way I am in the same situation choosing. I want to build a Watt Puppy clone and have been offered secondhand Focal tweeters. As I have some SS 9500, 9800 and 9900 lying about, I want to use any of these instead if they are suited for this exact job. Can you give me advice on this? Thank you. Mingo |
#4 | |
Hi Zaph, What about the R2904-700000? Have you used the D3004/6600? |
#5 | |
Did you ever listen to the Beryllium tweeter? Far superior than even the Scan R2407!! The t120 Tdx is not soo good, of course, but if you use them, be carefull in the XO design. The driver that Focal sold in the past may not be technically seen the most sophisticated; but some industrial Focal design (and thus unavailable for DIY normally) are technically advanced, and sound good. Try a 6" W diaphragm mid-woofer, and don't be surprised that it sounds better than a 18G from SS. There is only on 6" driver than beats both: the Audio Technolgy C-Quence 18H is simply the finest on earth. Maybe one day Focal will put drivers available again for DIY, but then also the Beryllium tweeter also, please. Cheers, - dan
It is worth to keep your mouth shut and let people think you’re stupid; rather than to open it and thus eliminate any doubts... |
#6 |
ok. harrisni,
try to choose your main driver first, let's say the 200-2K/voice - speaker driver first, and from there and on, with your finances, go and choose what you need to complement, 2 way or 3 way. Cheers Nice moto, Alfetta87. |
#7 |
6600 is better than 7000 imho. And as woofer there is only one brand, Audiotechnology.
#8 | |
#9 |
I know Zaph is not that careful...
Zaph, maybe you will not like. And the graph that say's PHASE on top and does not show it is the worse because we start looking for the phase somewhere... I like your (Zaph) driver pictures though... and bet there is a lot of work (there) that is not showing. I assume you have a "lot of money" and no time to spare. (Obvious not) And I don't want to be that bad, this is just envy. Keep the good work.
#10 | |||
For my own designs I don't use, keep track of or require acoustic center info. Everything is relative to the baffle. But I design using actual in-box measurements. For those not doing their own measurements, having to take a guess at the acoustic center setback of the woofer is the price paid.
-Zaph|Audio- |
| ScanSpeak-Seas- Focal drivers for sale | Antonio | Swap Meet | 16 | 21st March 2011 01:35 PM |
| Focal 6v4211 vs Scanspeak 18W/8545K | goolan | Multi-Way | 0 | 17th January 2007 06:24 PM |
| Assorted items, Plinius amp, Focal Peerless Scanspeak drivers etc | Al.M | Swap Meet | 0 | 7th November 2004 03:39 PM |
| Building new speakers, FOCAL or SCANSPEAK ? | jomor | Multi-Way | 29 | 10th August 2004 08:50 PM |
| WANTED - drivers and tweeters, focal, vifa, scanspeak or SEAS | griff | Swap Meet | 5 | 1st March 2002 04:16 AM |
| Page generated in 0.11497 seconds (81.92% PHP - 18.08% MySQL) with 10 queries |
