Old 1st February 2007, 03:40 AM   #1
sdclc126's Avatar
Default Tang Band W1-1070SE
http://www.partsexpress.com/pe/showd...number=264-860
Hi All,
Has anyone used/measured this driver? I was thinking of only using it as a tweeter in surround speakers - mostly DSP for music rather than HT - so demands would not be great.
Other than looking kinda cool I was just wondering if it was reasonably clean/accurate. I also thought given its very reasonable price and small footprint that it might be a candidate for line arrays.
Thanks!
Soft Dome
Old 2nd February 2007, 02:17 AM   #2
sdclc126's Avatar
Bump (I'll only do this once). May buy a pair just out of curiosity (and because they look so cool).
Soft Dome
Old 28th February 2010, 12:46 PM   #3
Hi SDLC,
an old post I know, whoa 3 yrs old!
but yours was a good question on a seemingly good driver with 170Hz FS, amazing!
So why didn't anyone reply? They seem great and for line arrays.
But I don't know, lol, I'm a beginner!
Grant
Old 28th February 2010, 12:48 PM   #4
oops sdclc...
Old 13th December 2010, 04:22 PM   #5
brsanko is offline brsanko  United States
brsanko's Avatar
Send a message via MSN to brsanko
Hese are fantastic drivers for arear loaded hor configuration. In small bookshelf sized enclosure they can easily go as low as 100hz at decent volume. A horn loaded array of eight of them can go as low as you like and because their mass is so low and the cone is so stiff along with a strong magnet hornresp shows the best impulse response I've ever seen.
PASSIONN
Old 13th December 2010, 05:30 PM   #6
brsanko's Avatar
Oh yeah, we did make some small bookself speakers out of a pair of these and they sound great but we designed them to go down to 80hz and for this to work well you need a sharp high pass crossover or the cones will move too much and pop at mid to high volume. Otherwise they sound absolutely fantastic. High frequency is exeptional. Sorry I don't have any photos. I plan to build my entire home theater using 7 channels with 8 of these each and 2 ginormous subwoofers each containing 4 MCM 55-2421 8" subwoofers. Should give me 135db from 20-20,000hz with an almost perfect impulse response. I'll put a link when I post pics of the planned theater.
PASSIONN
Tang Band W3-593SF vs. Tang Band W3-926SD Zaputh Full Range 17 5th June 2009 11:37 PM
Tang Band MTM ? wrenchone Multi-Way 11 21st November 2007 06:39 PM
8 x 12 Tang Band troystg Subwoofers 3 2nd February 2007 03:37 AM
Tang-band 2-way (W3+W8) haffe Multi-Way 10 31st January 2007 11:11 PM
Tang Band W1-1070SE - 1 inch transducer with 170 Hz Fs? arjscott Multi-Way 4 17th November 2006 02:51 PM
Page generated in 0.09011 seconds (73.05% PHP - 26.95% MySQL) with 10 queries
