Old 29th January 2007, 07:55 PM   #1
zlast is offline zlast  United States
Send a message via AIM to zlast Send a message via MSN to zlast Send a message via Yahoo to zlast
Default Nht 1259
I was measuring the T/S parameters of the NHT 1259 (origonal 4 ohm version) using the process outlined here:
http://sound.westhost.com/tsp.htm
Using a computer with tone generating software, 10.1 ohm resistor and multimeter, and the LS-PARAM.XLS I get the following results:
QMS: 3
QES: .66
QTS: .54
VAS: 150 liters
I am using a 45 liter sealed enclosure for the VAS measurement, with the same tone generator - resistor - multimeter setup as above. QMS, QES, QTS are all near manufacturer specifications, but VAS is considerably different than the 190-230 liters specified by the manufacturer. Has anyone else measured the 4 ohm 1259? Are my measurements off ? Is there some flaw in my measurements? I have repeated the measurements 3 times and get similar results. The 1259s are from the ORIGONAL group purchase through Ken Kantor....anyone else own/measured these? Are the parameters different than later 1259s ?
none
Old 29th January 2007, 10:17 PM   #2
infinia is offline infinia  United States
infinia's Avatar
Hi
What was the measurement of both fs's?
edit> I mean free air Fs and 44 liter Fb.
I would be upset when Vas was larger than spec.
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Old 29th January 2007, 11:26 PM   #3
Default FS
Free air (suspended about 4 feet off floor - no objects within 3 feet) = 20 Hz
FS is 45 liter enclosure = 40 Hz
Both measurements made with the tone generator, resistor, multimeter setup. THe concern about accurate measurements is over designing a Linkwitz transform circuit for several drivers. I started with the 1259 and want to make sure the results are correct befor designing the transform circuit. Any ideas ?
none
Old 30th January 2007, 10:46 AM   #4
infinia's Avatar
Hi Zlast
I would just put them in a reasonably small sized box using your meas T/S. I don't think you'll be too far off using your meas. Vas. Re-measure Fb, Q in the final enclosure and use those for the LT circuit. Design the LT for new Fs and Q watching gain doesn't go much above 8-10 dB.
BTW I calc Vas = 140 liters
FS: NHT 1259 subwoofer Jimmy D. Swap Meet 3 1st December 2008 01:55 AM
nht 1259 wicho Subwoofers 8 26th October 2008 03:22 AM
Nht 1259 Wanted!! maal1605 Subwoofers 8 7th January 2007 02:44 PM
WTB nht 1259 NickC Swap Meet 0 14th March 2006 04:00 AM
Page generated in 0.08297 seconds (71.97% PHP - 28.03% MySQL) with 10 queries
