Old 27th January 2007, 03:57 AM   #1
Send a message via AIM to black300zx
Default Designing x-overs - account for room effects?
Some background on my projects:
Input on some MTM's
Right now I'm in college, commuting back and forth from my parent's house. The set of MTM's I'm designing I hope to keep for a long time, which is why I'm starting with higher end drivers, and why I'm setting the bar high for their performance. I don't want to "outgrow" these speakers in a year or two and get the urge to build something better. These will hopefully combine with the stereo substage (that do dual duty as stands for the MTM's, see pic in above thread) to be a full-range 2channel setup for a room in my house, once that time comes.
Now for the question/problem:
My room is pretty small, and has horrible acoustic properties. The only sound treatment I could really do is to put a couple foam wall tiles (likethis) on the side walls a few feet infront of the speakes to hopefully reduce early reflections. The room is obviously going to impact the f/r of the speakers greatly, and it's effects surely will be different from those of the room that they'll reside in in the future. I'm probably going to be living in this room for at least another year and a half, and up to maybe up to almost 3. Should I try to design the x-overs for these MTM's around my current room, in an attempt to get a smooth/flat in room response w/o equalization, then redesign the x-overs in the future when I move? Or would it be a better idea to design them to have a flat on/off-axis anechoic response, and simply use some equalization to correct the in-room response? The future room will likely be much bigger, and will have some acoustic treatments, so room effects shouldn't be as significant as they are in my room.
One thing to consider - I'm building these speakers with an external box for the x-overs, so the x-overs will be easily accessible for modification, or complete replacement.
Old 27th January 2007, 04:54 PM   #2
myhrrhleine's Avatar
Personally, I'd design the best crossover I could and use a cheap equaliser for a temporary fix.
Then, later, i'd upgrade the EQ inside parts.
Just because you can't hear it doesn't mean no one can.
Old 30th January 2007, 11:09 PM   #3
any other opinions?
Old 30th January 2007, 11:47 PM   #4
What M. said. Correcting the room with the crossover is _not_ the way to go because you'll be tweaking endlessly. That might be fun to some folks (said the master of alligator clips), but when you move there's already enough aggravation that you don't need a week of fiddling with your crossover to enjoy music, especially since the new room is likely to have FR aberrations someplace else anyway!
Francois.
Old 31st January 2007, 12:07 AM   #5
lndm is offline lndm  Australia
Just what sort of corrections are you talking about?
eg: I feel a gentle tonal skew across the spectrum can be fixed at the crossover. So can a compensation for a live/dead room sound, and bass integration with the size of the room and personal taste should, I feel, also be dealt with at speaker level where possible.
Old 31st January 2007, 01:33 AM   #6
infinia is offline infinia  United States
infinia's Avatar
Hi
I would just add a couple DTDP switches with labels on the back wired to the crossover.
Examples of the 2 switch labels could be
Nearfield/ Far
Hot Room/ Normal Room
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Old 31st January 2007, 03:26 AM   #7
Not really sure. This is my first real attempt at designing a set of speakers completely from scratch, and it's going to be a fairly long term project. I expect it to drag out probably until the fall, if not longer, due to me being in school and having to work. I don't have the speakers yet, so right now I'm just in the planning stage, trying to figure out how to approach designing them. Basically what I was asking was this:
If I wind up with an anomally in the response due to the interaction with the room, and it can be corrected by tweaking the crossover, or by eq'ing, which route is better? From the few replies I've gotten so far, it seems like it's just a narrow spike or dip in the response, then eq'ing would probably be the best approach. If it's over a wider range, and it can be corrected in the x-over, then that may be the better route.
Thanks for the input, it's appreciated. I'm sure once I get into the actual design phase I'll have plenty more questions.
Old 31st January 2007, 07:52 AM   #8
The following is my opinion.
Spikes and dips that cover a very small frequency range can be safely ignored.
Speakers need to be chosen to suit the room vis-a-vis their 'size' or bass depth versus the room.
Speakers and listeners need to be positioned so as to avoid gross anomalies.
EQing, to suit anomalies is a matter of taste. It will alter the balance of sound in the room as a whole. I prefer not to use it myself for room dips and peaks, but I will EQ the bass contour if it suits a design, or the treble level if I feel the need.
Old 31st January 2007, 08:18 AM   #9
Perhaps just use a variable l pad (pot style) for the tweeter is all thats needed.
The acoustic tile idea will work very well from experience, it is also good to place damping material behind and if possible next to the box for the earliest reflections if close to the walls. This is in my experience the most dramatic improvement one can make.
Nasty Room Resonances in New Listening Room TubeHead Johnny Multi-Way 4 23rd May 2009 11:13 PM
Designing a home theatre room paulspencer Everything Else 12 6th July 2007 06:57 AM
Designing and measuring a speaker for a given room. Padel Multi-Way 7 29th January 2007 11:39 AM
Designing a box based on room dimensions StevenLB Subwoofers 1 14th December 2005 08:56 AM
Designing a decidated audio/HT room Volenti Multi-Way 1 13th December 2003 02:42 PM
Page generated in 0.11469 seconds (81.16% PHP - 18.84% MySQL) with 10 queries
