Old 26th January 2007, 03:17 PM   #1
sandstorm33's Avatar
Default 2 Way Crossover Help???!!!
I am putting the finishing touches on a pair of speakers based on Rick Schultes article in AUDIOXPRESS ,Oct 2005. What has developed is a 7" wide baffle holding a 5.75" Peerless HDS 830882 mid woofer 8 ohm. The box is 42" long and has a 33 sq.in cross section. The tweeter is an AUDAX TM020J5 neomydium 3/4" titanium unit 4 ohm. The tweeter is 3 or 4 points brighter than the Peerless. The woofer seems to have serious breakup above 7khz. My major concern is Baffle Step compensation and its relationship to the rest of the crossover. Using David Weems information I calculated an inductor value of 2.2 MH with an 8 ohm resistor paralleled . After that I am at a loss . I figured 2nd order on the tweeter and 1st order on the woofer at 4 khz xover.
Questions arise about total impedance of the crossover and where the BS inductor is placed in the crossover. I no longer have serious test equipment only a very good Fluke meter. I have to purchase the crossover components and will buy decent stuff so I would prefer to get it right as can be on the first go .
Old 27th January 2007, 03:05 PM   #2
Send a message via AIM to 69stingray Send a message via MSN to 69stingray Send a message via Yahoo to 69stingray
Try using the free FRD tools to reconstruct the design. You can include the baffle step. I like PCD (Passive Crossover Designer) better then Speaker Workshop.
http://www.rjbaudio.com/Audiofiles/FRDtools.html
Audio DIY Page
FOLLOWMY529.COM - Subscribe and follow the performance of my daughter's 529 College Saving Account.
Crossover for vifa 2 way setup - how can I find out what this crossover is doing? Tino Multi-Way 11 17th May 2009 05:21 AM
Help me with a crossover. raypalmer Multi-Way 4 5th April 2009 02:48 AM
Passive crossover into active crossover hahfran Multi-Way 16 10th February 2008 07:16 PM
Crossover help please :) Tenson Multi-Way 17 15th April 2006 10:34 AM
Can you hear the crossover point of a speaker with a well-designed crossover? 454Casull Multi-Way 11 2nd April 2004 06:48 AM
Page generated in 0.06897 seconds (69.58% PHP - 30.42% MySQL) with 10 queries
