Old 24th January 2007, 05:42 AM   #1
Nordic is offline Nordic  South Africa
Nordic's Avatar
Default Germans build concrete cast 5.1 speaker set
Thought you may enjoy this one...
Concrete and wax molds used to make small speakers and sub... Good training wheels for bigger projects.
http://propirate.net/betonboxen/
Old 24th January 2007, 05:58 AM   #2
Send a message via AIM to Spasticteapot
Very nice!
I was thinking of making a transmission-line speaker, and while ridiculously heavy, concrete does have the definite advantage of being non-resonant.
Old 24th January 2007, 06:06 AM   #3
weissi is offline weissi  Europe
weissi's Avatar
Not Germans - Tyroleans Although some of them were born Germans....
regards / servus
Old 24th January 2007, 06:18 AM   #4
This could be done much, much more easily with "blucor" insulation foam and a hot-wire cutter. Just melt it out with acetone or gasoline, and you're done.
I wonder what the density of concrete is?
Old 24th January 2007, 09:10 AM   #5
Nordic's Avatar
They are designed to hit you like a brick...
You got to love them for thinking the whole project through, getting all the materials BEFORE THE TIME, giving it a professional finish etc... I guess a melted layer of wax works good as dampening material...
Old 24th January 2007, 03:44 PM   #6
A good way to build some high end cabinets. However, concrete is weak in tensile strength so the walls if that thin should be reinforced with something. Maybe random glass fibers in the mix. IF you drop it it's history.
EDIT: After looking at the pictures again I see that there is a reinforcing mesh around the slug.
Using this technique and some synthetic castable marble would yield really good results. You could also sandwich a brace in between the wax slugs and wrap it in fiberglass to make some reinforcing. The wax can be recycled by pouring it into a retangular mold.
This gives me an idea for the head unit of some three ways that I am going to build. Maybe I will go all out and make a Wilson quality top cabinet.
The unfortunate thing about concrete is that it takes 30 - 90 days for the concrete to reach full strength. But at least you would be knowing that the sound quality would increase for for a period of time.
It would be interesting to see some TL build this way. You coud use thin plastic scraps from the sign shops that are usually sold for 1 dollar a pound for the mold cavity. Then tape them together and brace them and leave one side open. Installing bolt ancors in the cement. Then you have a very good cabinet and one side removable to adjust internal dampening. Which in a TL is very important to get just right.
Old 24th January 2007, 04:09 PM   #7
Speakerholic
Cal Weldon's Avatar
Post Haste?
28 days at 20C and standard inside humidity will get you there.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 24th January 2007, 07:14 PM   #8
The density of concrete depends on the mix, but normally it will be similar to aluminium (yes you read it correctly) about 2200 - 2600 kg/m3 for concrete, while aluminium is about 2700-2900 kg/m3
Curing of concrete never stops, at least for the first couple of years, therefore a standard measure in time, 28 days, is taken at which the prescribed strength has to be yielded.
Old 24th January 2007, 07:20 PM   #9
roger_lew's Avatar
That is 150 lb / cubic foot for those of us who are use to thinking in SI
http://www.google.com/search?q=2400+...to+lb%2Fft%5E3
Audio Nirvana Super 15" cast frame build mikeineugene Full Range 10 16th October 2011 04:36 PM
Concrete Pipe Speaker TEXAS TOMM Multi-Way 5 7th October 2008 09:19 AM
Concrete speaker Dr.EM Multi-Way 17 14th February 2007 01:36 PM
concrete board as a speaker cabinet serosmaness Full Range 12 28th November 2005 09:57 AM
Huge Concrete speaker cabinets in foundation Graydon Subwoofers 12 17th November 2004 03:53 PM
Page generated in 0.11725 seconds (81.38% PHP - 18.62% MySQL) with 10 queries
