Active Single Stage Butterworth 3rd order HP Calculator? Active Single Stage Butterworth 3rd order HP Calculator? - diyAudio
Old 24th January 2007, 03:46 AM   #1
HiFiNutNut is offline HiFiNutNut  Australia
Default Active Single Stage Butterworth 3rd order HP Calculator?
Where can I find it on the net? Have you got a link?
I have found the excellent site http://www.beis.de/Elektronik/Filter/Filter.html by Uwe Beis (thank you Uwe!) but it has only the LP Calculator. I don't know how to convert a 3-pole single stage LP to a HP.
Any links or information will be highly appreciated.
Thanks.
Bill
Old 24th January 2007, 10:18 AM   #2
consort_ee_um is offline consort_ee_um  United Kingdom
You can use Uwe 's excellent on-line calculator and then transpose the capacitors to resistors and resistors to capacitors keeping the impedances the same at the cut-ff frequency so for a 50Hz low-pass filter
First column is Uwe's calculated values for a 50Hz filter
Second column is my transposition using Z=1/2piFC
R1 = 5.84k c1 = 545nF
r3 = 9.5k c3 = 330nF
r5 = 8.5k c5 = 374nF
c2 = 680n r2 = 4.7k
c4 = 1uF r4 = 3.18k
c6 = 100n r6 = 31.8k
The second column gives a high pass filter with a cut-off of 50Hz and a slope of 18dB per octave
Only problem is that Uwe has chosen the LP capacitors to be standard values and the new values are not standard, although I could not resist rounding r2 to 4.7K and c3 to 330nf.
Old 24th January 2007, 11:01 PM   #3
Uwe's use of unity gain S&K forces one to adopt quirky values for the capacitors.
If one adopts the equal value component S&K then the gain setting resistors can be chosen to make the Q=1 completely independant of the frequency setting components where R1=R2=R and C1=C2=C. Much easier to select suitable capacitor values and by using either a pair of parallel resistors for each R or a series pair for each R to obtain any frequency with standard E24 values.
National Semiconductor ap note 779 and oa26 apply.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 28th January 2007, 09:37 PM   #4
Thanks guys. I have got it.
Active Single Stage Butterworth 3rd order HP Calculator?Hide this!Advertise here!
Phase control in 4th order butterworth MFB LPF xitronics Analog Line Level 1 8th June 2007 02:25 AM
My 1st order butterworth filter better than 4th order L-R: Why? philipreji Solid State 61 1st March 2007 04:50 PM
Butterworth vs. Bessel vs. 2nd order... squidbait Multi-Way 7 7th April 2004 04:18 PM
(LONG!)Crossover Design - 2nd Order Butterworth with attenuator GeniX Multi-Way 2 22nd October 2002 11:03 AM
what's the formula for 3rd order Butterworth ??? bbaker6212 Multi-Way 2 9th August 2002 12:47 AM
Copyright ©1999-2017 diyAudio
