Old 22nd January 2007, 06:02 PM   #1
Code is offline Code  United Kingdom
Default Improving a set of speakers
I have searched with no success so;
Is there a way to calculate ideal T/S parameters from a specified box size?
I'm hoping i can replace my drivers, tweeter, crossover with a more up to date solution (the speakers are at least 20 years old).
Old 22nd January 2007, 06:14 PM   #2
Glowbug is offline Glowbug  United States
Glowbug's Avatar
I'd tackle it the other way, looking at speakers' recommended enclosure sizes and going from there. BassBox6 Pro and WinISD could be useful...
Why not just build new enclosures that are perfectly suited to your new drivers? I'm sure you can find some help here...after all, this *is* DIYaudio!
Jim J.
Old 22nd January 2007, 06:19 PM   #3
Hmm, your approach seems rather time consuming, I will continue my search for the original driver specifications.
I would make new enclosures but my woodworking skills are particularly lacking.
Besides these seem to be high quality boxes and i think they look great
Old 22nd January 2007, 06:57 PM   #4
Andy G is offline Andy G  Australia
Andy G's Avatar
perhaps if you post the box volume and the port size, someone may have built a box of similar dimensions, and can point you to possible drivers.
also, what size holes you have already etc
Old 22nd January 2007, 07:07 PM   #5
Worth a shot
External dimensions:
Width: 27cm
Height:57.5cm
Depth:29cm
Side thickness: 112mm
Port length:14cm
Port width:2inches
Mid/bass: 8 inch tpx, made by Audax i believe.
Tweater: 3.5cm metal dome. "monitor audio" is written on the rectangular face plate.
Old 22nd January 2007, 07:47 PM   #6
Additional information;
The mid/bass has the following written on the back
MTX 2CX25 TDSN
M = chassis magnesium
TX = membrane “TPX”
2CX25 = size i think?
TD = something to do with the magnet?
SN = suspension “NORSOREX”, a kind of Neoprene,
8OHM
2CN12 = winds mobile 2 layers coppers (2C), on Nomex support, 12 mm length.
1377 - manufacturing number
The tweeter is a "MD900" by MA ( Monitor Audio )
Photographs of the crossover network in progress.
I'm under the impression replacing ageing electrolytic capacitors may improve things? They were 19 years old as of yesterday
Old 22nd January 2007, 09:03 PM   #7
tweeter crossover?
http://i14.tinypic.com/2nvqhdj.jpg
other crossover:
http://i13.tinypic.com/47bro14.jpg
mid/bass back
http://i13.tinypic.com/2q07g51.jpg
mid/bass front
http://i18.tinypic.com/4h1fzft.jpg
Maybe that ferrite coil could be improved?
ICW any good?
Old 22nd January 2007, 09:15 PM   #8
Send a message via AIM to Spasticteapot
Monitor Audio is good stuff.
I'd replace the surrounds (if they're brittle), and all the capacitors inside. Double-check for voice coil rubbing, and maybe replace the internal damping - fiberglass insulation should work well.
If all else fails, just sell 'em and buy a pre-made pair of cabinets from Parts Express.
Old 22nd January 2007, 09:58 PM   #9
Thanks for the advice
Regarding the voice coil rubbing, im not sure how to check on this?
I have noticed there to be a small amount of 'gritty' resistance as i move the suspension up and down, could this be the voice coil?
Finally, are there capacitors you would recommend?
Old 23rd January 2007, 01:22 AM   #10
For caps, go with good old fashioned polyester. Apexjr has some at low prices.
Gritty resistance sounds like voice coil rubbing to me!
Improving Vifa P17 paulspencer Multi-Way 22 24th July 2008 04:32 AM
Help me improving my pre-amp! thanh Solid State 0 26th January 2007 10:08 AM
improving bass response - yamaha speakers s115ivs sidpro Multi-Way 1 3rd April 2006 07:40 AM
improving the Mcintosh C22 Craig405 Tubes / Valves 22 13th July 2005 11:36 PM
improving my VAS djdamix Solid State 27 13th February 2005 12:54 PM
Page generated in 0.10662 seconds (78.79% PHP - 21.21% MySQL) with 10 queries
