Non polarized Caps
Non polarized Caps
Old 5th January 2003, 11:14 PM   #11
Ilianh is offline Ilianh  Canada
Ilianh's Avatar
Send a message via MSN to Ilianh
well the thing is a 200 uF NP cap is around 10$, a polarized 400uF one is around 50 cents (even less) here.
for a 5 speakers system where you use second or third order Xo's... that might save you a nice 80$ or so, wich btw is alot of money...
considering I could make a whole subwoofer with that money.
Old 5th January 2003, 11:26 PM   #12
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Default MORE OF IT
Not that I want to discourage you from running experiments but IME it does not yield good results in a X-over.
Also I'm surprised at the cost ratio between the two of 1:10 which may hold true for a 200 mF but for smaller values?
Re:
Any ideas on this one?
In a X-over these diodes aren't going to do anything useful since no DC is present.
Frank
Old 5th January 2003, 11:31 PM   #13
Ilianh's Avatar
I use them here as half wave rectifiers... diodes are not only used where dc is present
basicly the ratio is about the same,
On a 10 uF one, wich is aorund 3$ for a NP, its aorund 5 cents for a polarized one..
Btw,
how low would you make a cut with 200mF?
200mF would make a nice 10hz highpass filter
but ouch on the price of a NP 200 mF cap..
Old 5th January 2003, 11:39 PM   #14
fdegrove's Avatar
Default TRICKS OF THE TRADE.
A bit tongue in cheek:
Don't forget diodes aren't linear in behaviour.
I look at what I need for a complete project and than try to figure out a way to buy n *n value and // those values where appropriate so I get a volume discount.
It may not be applicable to your project though.
Ciao,
Frank
Old 6th January 2003, 12:48 AM   #15
Bobken is offline Bobken  United Kingdom
There seems to be a huge and quite disproportionate difference in the price of these different types of caps, in your country.
Especially (as Dhaen & Frank have suggested) as the non-polar caps are (mostly) simply two polarised ones in the same can.
I say mostly, since I am not sure without looking it up whether this is precisely how the very special non-polar Black Gates are made.
I can get 200uf - 50 Volt non-polars for 1.10 each (considerably less than $2 US) in the UK, especially designed for xovers, but I would never use electrolytics in a speaker anyway.
If you wish to end up with a speaker that sounds even half decent, I would steer clear of any polarised electrolytics which merely cost a matter of a few cents, as they are most unlikely to give you a good sound, unless they are being sold at very much below cost!
You have been warned!!!!
Bob
Old 6th January 2003, 01:29 AM   #16
Ilianh's Avatar
Ive been checking all day, and the cheapest NP 200 uF cap I found was 6$ cdn.
not that bad...
anyone knows how much they cost at solen? its kindof near where I live
Old 6th January 2003, 01:38 AM   #17
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Non polarized Caps
Default Re: Re: Non polarized Caps
Originally posted by Bobken
Almost all, if not all, polarised caps appear to perform their function better when they have a distinct 'bias', or DC voltage differential across their two leads.
If you have connected the caps two positive leads together, you need to apply a (relatively) positive DC voltage to the junction, and similarly, If you have connected the two negatives of the caps together, apply a negative DC voltage here.
I don't necessarily agree with the thesis that bias improves
electrolytics, but for what it's worth, you can achieve a bias
by placing diodes in parallel with each cap, creating a bias
rather quickly when the amplifier drives the back-to-back
caps. You perhaps would argue that this might create some
distortion while the caps are biasing up, but playing a little
head banger music while warming your system up should
take care of that.
Old 6th January 2003, 08:18 AM   #18
vuki is offline vuki  Croatia
vuki's Avatar
Default cap bias
It seems that Nelson is right again - in an article recently published in british Electronics World magazine (already mentioned elswhere) distorsion figures for electrolytic caps were much better without bias. High quality film caps exhibited same performance regardless of bias. Back to back polarized electrolytics were worse than non-polar lytics, and very good results were achieved with non-polar lytics in unusuall (for this type of cap) back to back configuration.
Anyway, I wouldn't use electrolytics of any type for xover.
Vuki
Old 6th January 2003, 09:13 AM   #19
diyman is offline diyman
Default Non Polar caps
I find that Solen do carry a reasonable wide range of film caps up to about 300uf. Their prices are "fairly decent" in hifi terms costing about $20 to $30 for a 240uf 250V polyprop. The sonic improvement over electros I feel is quite justified.
I've also tried "motor starter" caps(by Plessey) which are non polar caps rated at 110V ac and found their sound quite good too!
ckt
Old 6th January 2003, 10:16 PM   #20
Ilianh's Avatar
hehe, the crossover will cost more than the whole 3 way speaker, including drivers and materials.
Non polarized CapsHide this!Advertise here!
Please help with polarized capacitor! A Sanchez Chip Amps 19 18th July 2014 08:34 AM
Black Gate Standard Polarized or PK Mini Polarized = Rubicon YK or YXE kurtbauer Parts 1 21st August 2008 06:50 AM
Is feedback cap polarized or Not Wynand Chip Amps 7 13th July 2005 11:11 AM
Large NON polarized Madmike2 Solid State 14 8th July 2005 11:32 PM
Non-polarized caps in gainclone? avenger Chip Amps 1 30th January 2005 06:10 AM
Copyright ©1999-2017 diyAudio
