I am looking for a really high quality tweeter that is also small, for a 7KHz Xover (so extends to 3KHz, but best quality from 7KHz up). I want it small so that I can place it close to the midrange driver and cross so high. The one I can think of is the Vifa XT25SC50 - the little neo version of the XT25. The problem is that it is not really as high quality as I would like (seems to have some ringing in the CSD) and from what I understand these tweeters have a rather narrow dispersion. I like wide dispersion Tangband seem to make a number of neo tweeters, but I have only seen measurements for the ones on Zaphs site. Anyone know if one of the others happens to be a bit special? What else is there? I am looking for something with rather exceptional performance. Thanks! |
#2 |
Zaph tested the d26nc-55-06e with very good results. Quite cheap if you can find it (I think it is out of production)
Vifa D26NC55 ($26) - Very smooth response with mild tilt down of a couple dB over it's range. Near perfect CSD without no high frequency garbage. *Very* low HD above 2.5kHz with a mild 3rd order peak at 1.6kHz. Almost a complete lack of tall order HD products. Well built small flange neo with heat sink and excellent internal construction. D |
#3 |
Thanks that one does look rather nice. The fact it is out of production is a bit of a PITA though! Also, the 3rd order HD is a little higher than I would ideally like, but it would suffice I guess.
#4 |
I bought some of those Vifas from Madisound recently, they may still have stock. I doubt you will find any real data but some of the high end car audio tweeters are very nice, Res Audio Detectors, Morel Piccolo. or could you cut down/make a new faceplate for a known good tweeter, something like the Scanspeak with phaseplug (number eludes me) Genesis use that model (or a variant of) in their high end absolute speakers.
| JVC Quality Ribbon Tweeters | ARRAY | Swap Meet | 4 | 27th June 2011 07:24 PM |
| Small, Inexpensive High Quality Film and Foil Caps | dsavitsk | Parts | 5 | 7th February 2006 01:25 AM |
| Low wattage, high efficiency, high quality? | Nordic | Multi-Way | 5 | 4th September 2005 11:12 PM |
| High Power High Quality Digital Amp | aspycaudio | Digital Source | 0 | 6th December 2003 09:49 AM |
| small, but high quality amp | Sukandar | Solid State | 19 | 14th November 2003 10:19 PM |
| Page generated in 0.07330 seconds (72.84% PHP - 27.16% MySQL) with 10 queries |
