Old 20th January 2007, 04:07 AM   #1
adrrad is offline adrrad  Canada
Default Cabinet Wall Vibration
I just want to let you know that I do not know very much about speakers. I've got a pair of a 2nd hand JVC 3 way loudspeakers. Once home and hooked to the amplifier I've noticed o strong vibration and bass distortion of one of the loudspeaker. Everything's fine at low volume, but once the amplifier volume overpasses 1/3 of the volume scale, the loudspeaker starts to vibrate and to distort the bass. I realized that it was the cabinet. When I pressed the lateral right wall of the cabinet with my hands, the vibration disappeared. It is very clearly for me that the cabinet vibrates. What should I do to fix it? Is there any chance for me to fix this issue? Thank you in advance....
Adrian
Old 20th January 2007, 04:25 AM   #2
Speakerholic
Cal Weldon's Avatar
Hi Adrian,
It may be that the speaker was dropped and a glue seam or two have come loose. Maybe you can install a full corner block to rejoin the sides?
EDIT: You may have to do this through the woofer hole if there are no removeable panels.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 20th January 2007, 06:40 AM   #3
frugal-phile(tm)
planet10's Avatar
if only one speaker does it, Cal's diagnosis is probably correct.
And it may not have been dropped. A large number of cabinets in commercial speakers are just poorly built.
New cabs would be the ultimate fix, but making sure the cabinet that exists is "tight" and the addition of more bracing (hardwood or plywood strips attached edge-on to the box can usually be added).
Also make sure the bolts/screws holding the drivers are cinched down tight.
Pictures?
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 20th January 2007, 01:28 PM   #4
Thank you Cal and thank you Dave for your replies. I think I know what's to do. Do you know a site where I can go and see how to fix it? I wanted to attach 2 pictures: front and back, but I did not know how to do it. Looking at the back side of cabinet, I could easily see that the cabinet has been hit or dropped… The speaker model is JVC SP-74BK.
Thank you,
Adrian
Old 20th January 2007, 04:15 PM   #5
Speakerholic
Cal Weldon's Avatar
Adrian,
To post a pic, just click the browse button under the reply window. It can't be very large though so use a low res shot. You can post one pic per window.
Old 20th January 2007, 05:25 PM   #6
Ang is offline Ang  United States
could always try popping out the driver and superglueing in a ceramic tile on the wall.
Old 20th January 2007, 07:33 PM   #7
TerryO is offline TerryO  United States
TerryO's Avatar
Originally posted by Cal Weldon
Adrian,
Cal,
I've wanted to post pictures in the past, but have never done so. What size picture is appropriate?
Thanks,
TerryO
"If you have to ask why, then you're probably on the right track."
quote from Terry Olson's DIYaudio Forum application
Old 20th January 2007, 08:14 PM   #8
Speakerholic
Cal Weldon's Avatar
Terry, it will tell you when you post. I think it's about 100K but I have had some slightly higher pass.
Old 20th January 2007, 11:53 PM   #9
Maybe it's a little bit late... I just found out how to add pics... Here are the pics with my vibrating cabinet explaining the "hot" spots...
File Type: jpg jvc sp-74bk front loudspeaker 008''.jpg (84.8 KB, 76 views)
Old 20th January 2007, 11:58 PM   #10
The back of the cabinet tells you its history....
Designing for on-wall/near-wall speaker placement morbo Multi-Way 4 27th November 2010 04:52 PM
in-wall/on-wall speaker? (axiom w-22 clone?) Scott_fx Multi-Way 0 22nd February 2007 02:08 AM
tube vibration smak Tubes / Valves 8 19th January 2006 05:25 PM
In-wall vs bookshelf spk flush with wall darascott Multi-Way 3 1st October 2005 03:16 PM
Opinions on wall to wall subwoofer array jmiyake Subwoofers 35 19th July 2003 11:26 PM
Page generated in 0.10253 seconds (76.55% PHP - 23.45% MySQL) with 11 queries
