I've build a speaker setup with closed cabinets for the mid/high's and transmissionlines for the low end.
The only thing left to do is to apply damping material in the transmissionlines. I know that the damping influences the impedance of the TL but that is not an issue since i am using seperate amps for the TL's. Using more damping material decreases the amount of high frequencies radiated by the port but what should i look for when using speakerworkshop? Does the output of the port have to fall of above the resonance frequency with a first order slope? any input would be welcome Kees. |
#2 |
You should post this in the fullrange forum, as there is a great deal of TL experience there.
| Damping factor in DIY amp | jaya000 | Solid State | 25 | 25th September 2008 11:27 AM |
| What to use for damping | afterglow | Full Range | 1 | 5th May 2008 08:01 AM |
| ZD5 damping? | zdr | Multi-Way | 2 | 10th January 2008 10:16 PM |
| BH 5 damping | kyrill | Multi-Way | 11 | 22nd June 2004 06:28 AM |
| Help~~damping | hitboy_sw | Everything Else | 4 | 13th February 2004 02:22 PM |
| Page generated in 0.06703 seconds (71.03% PHP - 28.97% MySQL) with 10 queries |
