This is not strictly DIY speaker building but more speaker repair. I have recently bought a second hand pair of Energy Pro 22 speakers. I've been waiting for a pair to come up on Ebay for a couple of years now and this was the first pair. I picked them up pretty cheaply as they were poorly advertised, the cabinets have some corner damage and one of the tweeters has a dent in the dome. After an audition last night it appears that the dent in the tweeter doesn't have any audible effect on performance. I would still like to have a crack at fixing the tweeter purely for the appearance factor. I have tried to 'suck' it out but no luck. I have heard that a vacumn cleaner can be used with great care or a small pin with a hook used to place a small home in it to pull the dent out. Even though I'd like to fix this but as the parts are no longer available I don't want to take any chances with it. A photo ot the tweeter in question is attached. Thanks, Glen. |
#2 |
i don't have any suggestions to fix the tweeter, but i do know that energy will re-build it for you if you really want the dent taken out. i had contacted them about fixing a woofer in my '22's - they don't fix the woofers anymore, just the tweeters.
#3 | |
like four million tons of hydrogen exploding on the sun like the whisper of the termites building castles in the dust |
#4 |
I don't know these tweeters, but if the dome material can handle it you might want to try some tape (gaffertape works very effective) just stick it on the dome carefull enough not to make the dent any worse and then pull it off like a woman getting rid of leghair
Just make sure it sticks reasonably well to the an as large as possible surface...scratch on the surface of the tape with your nail (or something else...) to make sure it sticks well enough... The vacume cleaner solution might damage the litz wires or even suck-out the entire membrane, I would be carefull with that... Hope it works just as well for you as it did for me many times...
Max. cone displacement can be several foot on any speaker!Too bad it can be done only once......
#5 |
Used the gaffer tape and managed to pull the dent out. Love the speakers and wouldn't mine getting my hands on the 22 ref con model byt I guess pretty rare in Australia.
#6 | |
I had two pairs of 22 References. I scrapped one for parts and gave the other to my son. I was using the Ref Cons as fronts and the 22 Ref as rear channels for HT. The Ref Cons are nicer, smoother sounding, much better bass, more detail, but definite family sound. The Ref Cons are more demanding of the power amp, due to a very low impedance in the bass (2 ohms IIRC).
Dan |
#7 |
Yes, Canada is a long way from us although it is downhill all the way to get here. I'm not even sure that the ref conns were ever sold here. I have notice that the 22's are not all that efficient compared to my Quad 22L's. I'm running them with a 120 wpc Consonance Ref 150 hybrid integrated which may be a little on the light side for power output for the 22's. Regardless of this I still love them and as I paid AU$200 (I think about US$250) for them they are definitely keepers even with the rough cabinets. They have a slightly recessed midrange but the rest of the sound spectrum more than makes up for this. I was thinking of upgrading the crossovers and internal wiring but it may not be worth it according to another thread in this forum. I'll keep looking for some Ref Conns but not keeping my hopes up.
#8 | |
Good to read it worked, and a pretty gentle method wouldn't you think? Given that it is done by someone who is carefull....
#9 | |
Dan |
#10 |
I take it the only way to get to the crossover is to take the driver/s out and therefor damage the material covering the screws on both drivers.
| Fostex PM2 Tweeter repair | kammhron | Multi-Way | 1 | 19th August 2011 07:16 PM |
| JX92S with ENERGY tweeter (specs?) | _henry_ | Full Range | 4 | 25th August 2008 04:32 PM |
| Tweeter foam/felt repair | focal7C | Multi-Way | 3 | 27th May 2008 09:33 AM |
| Magnepan ribbon tweeter repair... | mcelaj | Planars & Exotics | 2 | 17th May 2005 01:15 AM |
| Luxman Amp Repair - Crackle in the Tweeter | Super_BQ | Solid State | 4 | 2nd August 2004 05:13 AM |
| Page generated in 0.13039 seconds (76.54% PHP - 23.46% MySQL) with 11 queries |
