Old 15th January 2007, 05:09 PM   #1
Question Advisable CAPS for passive crossover
Simple question, what are the type of caps (brands ?) for high pass passive cross over ? Is there a difference in quality using one type of caps for low pass say for 100hz and when filtering at 8000 hz ? Whic would be most appropriate ?
Old 15th January 2007, 05:35 PM   #2
Speakerholic
Cal Weldon's Avatar
The opinions are varied on this one. Some say the caps are more important and some say the inductors are more important. Some don't care and will use electrolytics and iron core throughout.
I use electrolytics and iron core for bypass and when they're really big and I can't justify the cost of others.
I use metallized polypropylene or polyester for most of the series stuff.
Watch out, there are many opinions on this.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 15th January 2007, 06:36 PM   #3
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Clarity Cap SA is a good value for money, open, non gritty sound. Welsh product. For low-mid you can use MKT bypassed by 1uf Clarity SA.
Old 15th January 2007, 07:48 PM   #4
Andy G is offline Andy G  Australia
Andy G's Avatar
I think Cal has it about right.
Big value coils and poly caps can be very expensive. Not sure if I agree on the use of electros for shunt, but I'm going to argue ;-)
It also comes down to the drivers used. Expensive drivers MAYBE warrant more expensive components
But.. generally, for use with use basic quality drivers, use a good quality poly where you can afford the size. Air coils where they aren't to big or expensive.
For large caps , I like the Visaton SAF. I think I can maybe tell the difference over a regular electro.
Big coils, use iron cores unless you will be really driving the speakers hard, then you may need to consider dumping the fund for air cores.
Old 15th January 2007, 08:57 PM   #5
Andy G's Avatar
should read " NOT going to argue"
Old 18th January 2007, 04:23 AM   #6
How much do you normally spend on parts to build a good crossover
Old 18th January 2007, 05:25 AM   #7
Take a look at www.humblehomemadehifi.com/Cap.html
Pierrick
Pierrick
Passive crossover into active crossover hahfran Multi-Way 16 10th February 2008 06:16 PM
Fonkens and 6W - advisable? ianc13 Full Range 3 21st September 2007 05:27 PM
Is it possible or advisable to use a lake as a ground? tom1356 Everything Else 19 9th August 2007 05:19 AM
Passive Crossover for Passive Subwoofer? Toast_Master Subwoofers 23 30th April 2006 12:14 AM
Advisable PCB solutions for a DAC Sandor Digital Source 16 5th October 2005 09:44 PM
Page generated in 0.08870 seconds (72.49% PHP - 27.51% MySQL) with 10 queries
