Hello everyone, I am trying to design a small bookshelf speaker using Tang Bang's W5-704s speaker and Dayton Planar. I am using the FRD tools (http://www.pvconsultants.com/audio/frdgroup.htm )
I already have the planar, and therefore, would like to crossover as high as possible, I am thinking around 4,000 Hz. Zaph was nice enough to post the T&S parameters and freq. response from a set a he has. Tang Band w5-704s I traced his response and was about to get a nice 4,000 Hz crossover using a parallel trap filter and a 3rd-order Butterworth crossover. The problem I run into is when I add in the Baffle Step. My baffle is 11 in x 17 in and the hump in the baffle step matches perfectly with the hump in the frequency response, giving me 10 dB hump to deal with. I have tried a RL contour network, RCL trap filter and even the "baffle step" network, all with no luck. The best I can to is get the hump down to 4-5 dB. I was hoping the slope of the crossover would smooth it out, bit it didn't. My baffle is just about the same size as Part Express's pre-fab baffle and a lot of people use them without issues. I am doing something wrong here? If not, any crossover suggestions? Baffle Sim: Combined Response: Combined Response Imported into Passive Crossover Designer:
Audio DIY Page FOLLOWMY529.COM - Subscribe and follow the performance of my daughter's 529 College Saving Account. |
#2 |
I have no idea why your simulation is generating these predictions.
I do have experience with the transducer and would not expect you to be able to experimentally verify the predictions. I might suggest playing with other configurations to see what can change the prediction. Mark |
#3 |
Hmmm, something is wrong with your diffraction simulation. Check your numbers. If your baffle is 11" x 17", the first diffraction ripple peak should be below 1kHz. You show it at 2kHz. I don't think PE has any boxes of that size. 11" x 17" seems kinda big for a 5.5" woofer.
I find this woofer's natural response to integrate nicely with most normal size boxes for *very* smooth response. You might consider the .5 cu ft box (9" x 14") vented or the .38 box sealed. If that's your simmed-in bass tuning, it looks a little peaky also. I haven't used Paul V's program in a while, but try making it look like this:
-Zaph|Audio- |
#4 |
Thanks everyone- I think I may have figured it out....real stupid...I may have done the baffle sim in metric...
In the back of my mind I knew it had to do something with the baffle sim. I should of done the back-calculations sooner to verify the width vs. freq. increase. John- that is the predicted enclosure. Right now it has +3 dB @ tuning just because I know my brother-in-law like the bass. I think I am going to move the port to the back, if I do, I will remove the +3 dB because he should get reinforcement from the walls/room.
| Design Review: Tang Bang W5-704s Woofer | 69stingray | Multi-Way | 80 | 20th May 2008 07:45 PM |
| design help needed. | neazoi | Tubes / Valves | 14 | 8th September 2007 03:43 PM |
| Tang Band w5-704s | MITMechE | Multi-Way | 8 | 26th February 2007 02:38 PM |
| PCB and Design needed | prozach7 | Chip Amps | 0 | 15th August 2006 06:25 PM |
| Page generated in 0.09332 seconds (74.96% PHP - 25.04% MySQL) with 11 queries |
