Someone was looking at a pair of Bose 802's for PA use in a small gym.
Of course, my first thought was "You can do better than that!" Let's see if we can offer a hand to whoever it is, eh? http://forums.audioreview.com/showthread.php?t=21221 |
#2 | |
STP, I haven't heard the Bose 802's, but some of the Pro guys who also are audiophile/DIY'ers have said (on other forums) that the Bose Pro stuff is pretty good. Seems the Pro division is run by Engineers as opposed to the Marketing Jerks that dominate the consumer side. Best Regards, TerryO
"If you have to ask why, then you're probably on the right track." quote from Terry Olson's DIYaudio Forum application |
#3 |
For background music or speech they're fine, if a little more expensive than the competition.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#4 |
Some crazy suggestions she got on that forum .....1000-2000 to spend .... that should not be hard to solve
I once had some small PA Altec with 10" .... sounded pretty good and later we used some small ElectroVoice .... they were pretty loud ![]() edit... offcourse they will have to be raised above ground |
#5 |
These appear to be for music, for a dance class. They'll only be moved about twice a month, so I figure that they need not be as portable as 801's or even your average Mackies. A pair of line arrays would give ridiculous SPLs with audiophile-level quality, and once you factor in the integrated amplifier, they're not such a bad deal.
#6 |
Yes, I was thinking in light portable system - 2x12" should do the trick - but I guess we are not talking diy ?
| Wanted - High Power, High Voltage, Audio Frequency Transformer Manual. | kimbal | Tubes / Valves | 4 | 11th May 2009 08:05 PM |
| Wanted: A few feet of high quality *thin* solder... | Peteruk | Swap Meet | 6 | 11th June 2007 12:05 PM |
| High sensitivity(>90db) budget speakers wanted | kmj | Multi-Way | 40 | 28th April 2005 04:23 AM |
| Source wanted for High Quality On-off Switches | Jozua | Parts | 10 | 29th October 2004 08:29 PM |
| Wanted: high-end resistors | vdi_nenna | Swap Meet | 0 | 3rd February 2001 10:18 PM |
| Page generated in 0.09390 seconds (70.83% PHP - 29.17% MySQL) with 10 queries |
