Konus audio Essence - Page 5 - diyAudio
Old 8th January 2008, 11:27 PM   #41
scottjr is offline scottjr  United Kingdom
scottjr's Avatar
Default Transmission Line
Here is the completed speaker.
James
Old 16th January 2008, 10:57 AM   #42
Hi James, thanks for your support and ideas. I ordered the MDF and looking forward to start building the speakers. As soon as i have some results, i will put them her. Thanks again mate!
Old 16th January 2008, 11:43 AM   #43
ROVSING is offline ROVSING  Denmark
ROVSING's Avatar
You could use "sliced" MDF for the round pieces...just a thought.
Frandsen
Old 4th July 2008, 01:53 AM   #44
Hi everyone, thanks for your help and idears about my project. Here are some up-to-date pictures. It not so exiting for people who are building for a long time loudspeakers but this is my first project. Stíll waiting for the jx92s drivers (or the money for it......;-) Found out that a german supplier put`s a pci filter in his kit, why I realy don`t know. Looking forward to receive your comments and hints. So till soon
Old 19th July 2008, 12:20 PM   #45
scottjr's Avatar
Default Transmission Line Speaker
Your thansmission line speaker cabinets look very good. As there are MDF I assume you will either paint them of veneer them. I am still very pleased with my pair (in oak with MDF for the back and internal baffles). I am sure you will be more than happy with them once you get the drivers. What is the pci filter than the German supplier includes?
James
Old 24th August 2008, 08:20 PM   #46
lineup is offline lineup  Sweden
lineup's Avatar
Originally posted by pikkujöpö
How about the differences in sound quality between different materials
like MDF and birch plywood.
Something tels me to choise the MLTL diy version
but I kind of like the original Konus looks so much better
I was also thinking of useing birch plywood and "painting" it with epoxi inside
and then fitting veneer with epoxi as well.
But don't know if it is worth it.
Simple MDF would be so much easyer to buy in small quantities cutted to size.
I have built few speakers before
but this will be the first serious project with veneer and all.
Suomalainen
We have one of the most experienced loudspeaker profiles in our board.
He is somewhat of one expert on TL-speakers.
his diy website: http://www.t-linespeakers.org/
Now, I recall he once told us here in forum
he had found using real wood
was better than MDF in speakers cabinets.
I was very surprised to hear him say this. Even the most repsected speaker builder gurus, writing books! .. use often MDF for their speaker plans.
What should I think?
planet10 is a man that wouldn't tell things he was not sure of.
And he has got 1000 times more experience of practical speakers than me.
My Own final Conclusion on This Subject
Next project I build, I mean one SEEEEERIOUS hi-fi speaker system,
will use Birch Tree or some other heavy density Hard Wood.
And those 19 mm thick big MDF Boards I did buy
will have to be used only in some smaller & less serious speakers.
Lineup regards to suomi from ruotsi lappland, lycksele
Lineup audio speakers forum
http://homepage.mac.com/planet10/TLS...map-100707.pdf
Old 25th August 2008, 05:02 PM   #47
Hi lineup ! and regards to Sweden!
After all I went for MLTL48" design.
As I couldn't decide between wood or MDF...Glued 16mm MDF and 10mm hard density wood together(made for parquete flooring).
Unfortunately my room sucks the bass,in the listening position at least.Bass boosting the MLTL makes the bass"boomy" ,also the small jordan driver bottoms too easily with some music.
So now I have biamped system with bassreflex boxes, -3db 40hz.Makes the positioning a lot easyer.
The reflex ports in Jordans are filled with wool socks made by grandmother Best Christmas present ever.
Maybe I go crazy and fill the MLTL boxes with sand,below the driver
xxx I should correct my spelling xxx
Old 25th August 2008, 11:06 PM   #48
huguini is offline huguini  Argentina
Hi pikkujöpö, sorry but, where can I see the MLTL48" design? Do you have plans, or photos?
Thanx in advance.
Old 26th August 2008, 04:22 AM   #49
lineup's Avatar
MLTL48
yes, what is this?
Mark Levinson Transmission Lines speakers #48
probably ..... no
lineup
Old 26th August 2008, 01:29 PM   #50
Mark Levinson...I wish
Here you go: http://www.ejjordan.co.uk/diy/
The one in the left is MLTL48" :http://www.diyaudio.com/forums/showt...166#post765166
The MLTL's are designed by GM (user of this forum).
Don't get me wrong,the bass from MLTL's is of good quality till aprox. 35hz.My problem is the listening room.
Issues Of Asus Xonar Essence Stx fotios Digital Line Level 3 14th March 2016 12:42 AM
NIB ASUS Xonar Essence STX for sale or trade for a Juli@ Greg Stewart Swap Meet 1 2nd August 2009 03:47 PM
For Sale Or Trade: Adire Audio Brahma, Rythmik Audio Plate Amp tmort Swap Meet 5 27th June 2009 01:29 AM
Need schematic for Elevation Audio DX1500.1/Sundown Audio SAZ-1500D jaimegmr Car Audio 0 5th May 2009 07:39 PM
Asus Xonar Essence STX analog input? fotios Digital Line Level 1 25th April 2009 11:55 PM
Copyright ©1999-2017 diyAudio
