Konus audio Essence
Konus audio Essence
Old 4th January 2003, 05:59 PM   #11
BrianGT is offline BrianGT  United States
diyAudio Moderator Emeritus
BrianGT's Avatar
Send a message via AIM to BrianGT
I was planning on using Baltic birch inside and out. I think that it will help for rigidity. I was planning on using .75" thick throughout (19mm) and then double thickness on the sides and back, then 1" on the front.
Brian
Old 4th January 2003, 06:03 PM   #12
zeno is offline zeno  Europe
Sounds 'steady'...
It is actually a very female friendly speaker and that's why I will give it a try in 2003. New years' resolution...
Marc
Old 4th January 2003, 11:00 PM   #13
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Konus audio Essence
The JX92 is getting many, many accolades.
For a TL for these, i'd run some models using Martin King's software. The Jordan design (very similar to a Jordan-Watts design i did in 1976) seems a bit shy on box volume to get the most out of the driver.
Rick Shulz is using the JX92 as a design example in his upcoming alphaTL article in audioXpress.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 4th January 2003, 11:49 PM   #14
Variac is offline Variac  Costa Rica
diyAudio Editor
Variac's Avatar
Konus audio Essence
How about using the Oris horn/ Avant Garde horn idea with the Jordans? The advantage would be getting the efficiency from 88 db up to maybe 95 db?
Here's info on the Orris parts click around on the site and there is a lot of info:
http://www.welbornelabs.com/oris.htm
There is info online about designing your own tractrix horns, which is the most expensive part
I'm interested in opinions
Dave: I ordered my Fostex FE 208 EZ drivers yesterday, they might work well in an Oris type horn also?
"The geek shall inherit the earth"
2017 Burning Amp is November 12 in S.F. Thread here on diyAudio:
http://www.diyaudio.com/forums/clubs...francisco.html
Old 5th January 2003, 01:06 AM   #15
frugal-phile(tm)
planet10's Avatar
Konus audio Essence
Originally posted by Variac
[B]How about using the Oris horn/ Avant Garde horn idea with the Jordans? The advantage would be getting the efficiency from 88 db up to maybe 95 db?
But they would still be 88 dB in the mid & HF bands.
They might well do. You should go look thru Bert's Forum and see if it has been asked already and if not you can ask the man himself.
dave
Old 5th January 2003, 03:39 AM   #16
diyAudio Editor
Variac's Avatar
Konus audio Essence
ohhhhhhhhhhhhhh-now I get it
Old 5th January 2003, 06:13 AM   #17
BrianGT's Avatar
dave
Dave,
Any clue on when that aXp issue is coming out?
Brian
Old 5th January 2003, 06:35 AM   #18
BrianGT's Avatar
I am trying to do some mathcad simulations. I have all of the parameters except for the voice coil inductance for the jx92s. Do you have any clue where I can find this? It isn't listed on the Jordan JX92S spec page ...
Brian
Old 5th January 2003, 08:33 AM   #19
frugal-phile(tm)
planet10's Avatar
Konus audio Essence
It is not really a critical spec. You can pretty much get away with Vas, Qt, and Fs (i think).
I have also seen a geometric method of estimating it from the impedance curves. I can't remember where.
The date on the aXp article is unknown at this time. I hope it is soon.
dave
Old 7th January 2003, 07:36 PM   #20
LBHajdu is offline LBHajdu  United States
I to am planning on building a pair of the Jordan JX92S TL speakers based off the reference design on the Jordan website at some point.
One thing that can be done to improve the TL is to remove the sharp bands from the line. I have drawn a picture of the type of change I’m talking about. A very small compensation in volume may or may not be needed.
If as BrianGT says “the Essence is far, far superior” then I should very much like to know a little more about it. Perhaps someone who owns an Essence could with the aid of a mirror look up the transition line of the Essence to see if at least the last 1/3 of the tl is the same and report back on what they see.
Leve
Konus audio EssenceHide this!Advertise here!
Issues Of Asus Xonar Essence Stx fotios Digital Line Level 3 14th March 2016 12:42 AM
NIB ASUS Xonar Essence STX for sale or trade for a Juli@ Greg Stewart Swap Meet 1 2nd August 2009 03:47 PM
For Sale Or Trade: Adire Audio Brahma, Rythmik Audio Plate Amp tmort Swap Meet 5 27th June 2009 01:29 AM
Need schematic for Elevation Audio DX1500.1/Sundown Audio SAZ-1500D jaimegmr Car Audio 0 5th May 2009 07:39 PM
Asus Xonar Essence STX analog input? fotios Digital Line Level 1 25th April 2009 11:55 PM
