I've read various guides about splicing verneer, but I haven't seen anything about the best way to cover the 4 corners of the front baffle if all edges are beveled. Any good methodology for this?
#2 |
There is no easy way to do this. Most builders who want this effect use real wood roundovers for the four sides then just veneer the flat front, like these:
http://www.diyspeakercabinets.com/GR_Murphy.htm The reason it's not easy is twofold: most veneers do not bend well against the grain (you need to do this on two sides); it's both hard to get it flat against the surface and the veneer tends to crack; second, the shape you need to cut out of the veneer to do the corners is tricky (try this with a piece of paper and you'll see why), so you basically have to do two sides, trim along a curve, which is difficult, then do the other two sides. It's extremely difficult to do right. I'd either suggest doing roundovers on only two sides, using quarter rounds of real wood on all four sides, or using a real wood solid front baffle. |
| 12 " for lower midrange - upper bass | Audiodidakt | Multi-Way | 33 | 23rd June 2009 04:39 PM |
| Lower rails for lower impedance? | 95Honda | Solid State | 7 | 19th December 2007 08:59 AM |
| Upper and lower triode in E88CC | Andypairo | Tubes / Valves | 7 | 8th March 2006 06:51 AM |
| MTM’s or TMM’s: using sealed upper and TL (or similar) lower drivers? | Andy G | Multi-Way | 3 | 18th November 2002 04:46 AM |
| Page generated in 0.06281 seconds (67.58% PHP - 32.42% MySQL) with 10 queries |
