Old 10th January 2007, 10:39 PM   #1
Default New floor standers
Hi I want to make some inexspensive floor speakers im new at this so go easy on me. I listen to hard rock music mostlty if that helps. I thought a bigger woofer was always better all I see now is 6 1\2 ,8 Like I said I am new at this. Can ya help me please
Jeff
Old 10th January 2007, 10:43 PM   #2
Speakerholic
Cal Weldon's Avatar
Hi again Jeff,
Bigger is better, to a point. But we need to know...
How big is your room?
What amps do you have?
A 6.5 or an 8 are fine for small rooms but...
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 10th January 2007, 11:12 PM   #3
Speakerholic
Cal Weldon's Avatar
Jeff,
I just realized you posted this is full range and I moved it. Did you mean a single driver? If so I will move it back.
Old 10th January 2007, 11:36 PM   #4
Dumbass is offline Dumbass  British Antarctic Territory
What do you mean by "inexpensive"?
Look at pispeakers.com. They have sort of an old-school approach to speaker kits, big woofer + horn loaded compression driver.
Old 10th January 2007, 11:57 PM   #5
Send a message via AIM to Spasticteapot
Default Re: New floor standers
Jeff
The ZaphAudio Dayton Aluminum MTMs will run you roughly $250/pair with subwoofers.
http://www.zaphaudio.com/BAMTM.html
There's an option on the bottom for side-firing subwoofers, which will give you oodles of bass.
Alternately, the shielded version of the Silver Flute 8" woofer from madisound is only $40. It can go down to about 40hz without much trouble, though I reccomend using them with either a midrange driver or a tweeter capable of crossing over below 1.5khz.
Old 11th January 2007, 01:58 AM   #6
Default Room size/Amp
Its a carver 752 for the amp its 100 watts x 2 and my room is 10 x 14 its not a very big room. And as far as drivers whatever works best my speakers here now have 3 drivers but they are real sweetheart whitevan specials.
Thanks,
Jeff
Old 11th January 2007, 02:30 AM   #7
Default Re: Room size/Amp
Thanks,
Jeff
Unplug those suckers before you kill your amp - they're garbage. I hope you did'nt pay too much for 'em.
Go ahead with the Daytons. Even without a subwoofer, they've got decent bass, and don't cost too much.
Old 13th January 2007, 09:48 PM   #8
Geoff H is offline Geoff H  Australia
Jeff, this may be worth consideration. In your present room with your amp you should have plenty of headroom.
Please note, I have not listened to these. I want to, they look good on paper.
Being a dual concentric, easy for a newcomer. Have a listen before you decide. Better to spend a bit more now, than upgrade in 6 months time.
http://www.usspeaker.com/beyma%2012cx-1.htm
Just a word or to about listening tests. Note the ones you like, and go back for another check. It takes time to narrow down the choice, but see it as an investment.
Good luck with the hunt. And don't be afraid to ask questions.
Geoff.
Edit: The 8BX may be worth a look also. For the price dif, I'd go for the 12"
3 way revelator floor standers 20hurtz Multi-Way 3 11th December 2008 12:29 AM
Convert floor standers to subs with Tang Band 8" subs? prerunnerv6 Subwoofers 3 26th February 2006 01:44 AM
My head is scraping the floor Madmike2 Pass Labs 47 11th May 2005 10:35 PM
HOw close does driver need to be to floor to avoid floor bounce? Kanga Multi-Way 8 24th April 2003 07:09 AM
Replacing the floor Tim F Multi-Way 5 11th March 2003 10:14 PM
Page generated in 1.97006 seconds (-82.67% PHP - 182.67% MySQL) with 10 queries
