Old 9th January 2007, 09:09 PM   #1
pjpoes is offline pjpoes  United States
Send a message via AIM to pjpoes
Default Assembling Aria Crossover, some help needed
I was wondering if anyone could help me in how to wire this up. It seems like a simple enough design, but I've never made a crossover point to point like this, and wouldn't mind some input on how you all would go about handeling it. Thanks.
This is a method I found that looked good, does anyone have any problems with this style? Essentially it looks like he creates a star ground for the crossover, by tieing them all together, then creates a sort of horse shoe shape from there.
http://www.partsexpress.com/projectshowcase/xover/xover.html
Old 10th January 2007, 06:37 PM   #2
The method described in that PE article is fine. Having a crossover circuit board makes the soldering easier. I like the Madisound matrix or matrix double found here:
http://www.madisound.com/cgi-bin/ind...d=1539839.2138
The matrix double is large though (11" long). You could probably fit the Aria crossover on a single matrix although it will be more tricky.
Another thing is to physically arrange your inductors in perpendicular positions to minimize crosstalk. Read this article.
http://www.audioholics.com/techtips/...rcrosstalk.php
The arrangement shown in Figure 7,7a is ideal for the two tweeter inductors. Place the woofer inductor on the other side of the board and at a perpendicular arrangement to the two tweeter inductors.
Good luck.
Old 10th January 2007, 06:41 PM   #3
That is the first crossover for a tweeter I've ever seen with a built
in low pass filter (R1 +C3), are you sure the diagram is correct ?
edit : checked the Aria 5 - seems to be correct, seems a rather drastic method
of controlling the top end, and not so good for the top end end impedance.
C2 is shown as 1 to 3 uf (variable) in the 5.
/sreten.
Old 10th January 2007, 10:46 PM   #4
do you think its a bad crossover design for those drivers. I'm open to other suggestions. I have one method based on the Electra 905 crossover, but wanted to try something else.
Old 11th January 2007, 01:21 AM   #5
well I put in a few hours on the crossovers tonight. I'm still recovering from bronchitis and quite out of it, so I can't seem to concentrate on such things for more than a few hours. None the less, I got quite a bit done. I built one of the tweeter crossovers, now I just have the very simple woofer crossover to build. Then I'm going to have to find a way to mount it into some sort of box so that all the inductors are mounted correctly. We shall see how it goes. Anyone have any recomendations on the types of boxes I might want to mount them into. I was considering aluminum project boxes, then I thought about some ebay boxes, but wasn't sure if aluminum was the best choice.
Kef 105.3 assembling sandor626 Multi-Way 44 17th September 2010 10:09 AM
Tried assembling my own crossover...why didn't it work? PoorSound Multi-Way 5 16th February 2008 07:02 PM
FASE Aria speaker stands help needed.... sparkle Multi-Way 3 7th September 2006 09:11 AM
Finishing assembling a driver? Destroyer OS. Subwoofers 7 10th January 2006 10:12 PM
Best crossover for Vifa and Aria 2? Layberinthius Multi-Way 2 1st April 2004 08:02 AM
Page generated in 0.08908 seconds (74.17% PHP - 25.83% MySQL) with 10 queries
