Old 9th January 2007, 03:11 AM   #1
Default peerless 830883 Question
Have any of you noticed a difference on new vs older 7" HDS exclusives?
The older datasheets do not show a dip above 1KHz whereas the new datasheets do. Zaph's test seems to confirm the new datasheets FR.
The datasheets have different VAS leading me to believe that they changed the spider/surround without giving it a new part number. I also think the changes are more significant than just break in. The change happened around the same time peerless introduced the 831882
I bought and tested an 883 a while back, and don't remember that dip. Of course, I did not save the data and don't have the drivers.
Do any of you have older HDS exclusives that you can compare to new production, and show differences, either cosmetic or measurement based?
FYI, the madisound datasheet is the old one, Tymphany is the new datasheet.
www.tymphany.com/datasheet/printview.php?id=3
www.madisound.com/pdf/peerless/830883.pdf
tweeter advice for peerless 830883 flexus Multi-Way 47 30th December 2009 09:24 PM
830883, 830884 or ER18 ? Bad_mojo Multi-Way 29 20th March 2008 01:24 PM
bzdang question for Peerless HDS 182 AllCaster Multi-Way 2 30th November 2004 03:35 AM
Another Peerless woofer Question (CSX-10) LageB Multi-Way 4 26th April 2003 05:48 AM
Peerless XLS question Jean Multi-Way 6 14th March 2003 04:10 AM
Page generated in 0.06681 seconds (69.77% PHP - 30.23% MySQL) with 10 queries
