I have 3 speakers that are rated at 6ohms each and I am going to build the zaph audio hiviw5/vifa D27sg15 for some surrounds. http://www.zaphaudio.com/audio-speaker19.htmlhttp://www.zaphaudio.com/audio-speaker19.html
I am wondering if there will be any issues with the impedence differences between my 6ohm speakers and these. I'm not positive of the impedence of these speakers but I don't think it is 6ohms. Of course I can't remember how to calculate it anymore. If there is a difference, could I add a resistor to add impedence to the lower impedence speakers to correct the difference or would that cause even more problems? Thanks for your help. |
#2 | |
Are you using these in a 5.1 setup? If so, then you should be able to adjust the individual volume levels for each speaker on your reciever. All but the cheapest of recievers can drive a 6-ohm speaker just fine. If your reciever goes boom with 6-ohm speakers, odds are that you'd want to replace it anyway. |
#3 |
I will be using these in a 5.1 setup and possibly a sort of A + B type design using the two ways for stereo music and the other speakers for the rest of the surround. According to the calculations of parallel circuits, I think these are 4 ohm speakers. There are 2-8 ohm channels wired in parallel which using the equation 1/ (1/8 + 1/8) = 4. Is this correct based on the crossover design listed on zaph's site? I have a yamaha 5960 receiver and can choose 6 or 8 ohm resistance. Which setting would I choose if all I had to do was adjust the volumes of each of the individual speakers assuming this 2 ohm difference won't kill my amp and doesn't need to be corrected with added resistance? Thanks for your help.
#4 | |
First, the ZaphAudio speakers, if built properly, will be superior to almost all commercial speakers less than $500/pair. You may as well use them as your mains. The impeadance curve has some funny peaks in it, but never dips below 6 ohms - most of the time, it's effectively an 8-ohm speaker. I'd switch the reciever to 6-ohm mode just to be safe - your 8-ohm speakers should have no trouble, although they may not be quite as loud. |
#5 |
How do you tell the impedence from a graph? Is this the way it is normally done to determine impedence or is it a mathematical calculation?
Thanks for all your patience and help so far. |
#6 | |
#7 |
I think I see that now on the impedence graph. Thanks for your help. One more question:
If the speakers that I want to use together are disproportionate in volume together, would an easy fix be to add an L-Pad to the louder speakers without a huge negative effect on sound quality? |
#8 | |
Most recievers have an option for adjusting volume on each individual channel. That said, for music, you're better off just going 2-channel with the Zaph speakers. |
| Speaker idea based on Zaph ZD5, thoughts please, Zaph? | wigginjs | Multi-Way | 23 | 3rd April 2009 05:09 AM |
| noobie sub amp question | speakerbug | Car Audio | 0 | 10th December 2008 04:44 PM |
| Noobie question: which amp is best for me? | assasukasse | Solid State | 32 | 30th September 2006 09:54 AM |
| Page generated in 0.10861 seconds (78.20% PHP - 21.80% MySQL) with 10 queries |
