W18E001 + 27TDFC bookshelves, need design help (sonotube?)
Old 9th January 2007, 02:54 AM   #1
thadman is offline thadman  United States
Default W18E001 + 27TDFC bookshelves, need design help (sonotube?)
While im collecting funds to finish my line array Id like a set of nice bookshelves (ill be using them as computer speakers) to hold me off till I get them finished.
I just got a pair of Seas Excel W18E001s in a trade (man these are pretty) and the Seas 27TDFC (should I look at any other tweeters? remember these are just to hold me off till my line arrays are completed) are quite inexpensive and would be a worthy investment to hold me off. Would a T-amp work to power them for low level listening, or should I invest in a Crown XLS-202D?
I plan on using most of the existing equipment I have planned for the line arrays, which include the DCX2496 for crossovers and the XLS-202B for the W18E001s.
Also, I was considering buying a tiny sonotube (probably like 8-10" sonotube) and then cutting 2 slits down the side and inserting a piece of MDF to use as the baffle. From the top the sonotube would look like a C, without the baffle in place.
I dont have plans on building a subwoofer for the computer (but it may happen in the future with a Dayton RS15 and a plate amp or something along those lines), as these bookshelves would probably suffice for low level listening. Should I port them or seal them, and if I ported them how low should I port them?
Old 6th March 2011, 06:41 PM   #2
johngalt47 is offline johngalt47  United States
I have these drivers and need the .frd and .zma files for the Seas woofer. Does anyone have them?
Any technology sufficiently advanced is indistinguishable from magic
Old 7th March 2011, 09:54 AM   #3
I was quite surprised to see this post in my email, especially one from John Galt
Sadly I do not have the files, but someone possibly does. free bump.
"It is a profound and necessary truth that the deep things in science are not found because they are useful; they are found because it was possible to find them."
Old 7th March 2011, 10:32 AM   #4
jerome69 is offline jerome69  France
jerome69's Avatar
http://www.crestviewcable.com/~catapult/Seasdata.zip
Enjoy
Old 7th March 2011, 02:17 PM   #5
Thanks!
I tried using the freq response data in PCD but it doesn't look correct.
Old 29th January 2012, 01:06 PM   #6
I'm in the process of "tuning" the crossover for a W18E001 + Dayton RS28A-4. The guys over at Parts-Express are helping me with the crossover.
It looks to be a promising design.
Old 29th January 2012, 02:27 PM   #7
mdocod is offline mdocod  United States
Send a message via AIM to mdocod
If these speakers are run full range, you're going to be Xmax limited to ~10-20W with most program material depending on the box size/tuning/type etc. I think a little chip amp is all you need for both the highs and lows, but if you already have a XLS amp then go ahead and use that for the lows I suppose.
If they are going to be run full range vented is going to have more benefits than drawbacks IMO. If you add a sub later you could always plug off the vent and cram the boxes full of dampening material.
I like 0.75-1.5ft^3 range, anywhere from 25-35hz tuning depending on the room and desired bottom end loading/protection. If you want the boxes to stay a little smaller, ~0.5ft^3 tuned to ~40hz looks good to me as well.
Best of luck with the design!
Old 18th April 2012, 10:48 PM   #8
wallacefl is offline wallacefl  United States
would like to revive this old thread...anyone have a 1800hz crossover for the W18E001. I have a pair of OEM RAAL 20xr which that by design cross at 1800 and would like to give this combo a go...thanks
Old 17th May 2013, 10:01 AM   #9
Tolik is offline Tolik  Israel
Tolik's Avatar
Look at FRD of that driver... 16dB peak at 4.9K due to cone resonance. Its starts around 3.2K - 3.4K. So you need not only to damp it, but to prevent any harmonirs entering this range.
Calculanion is simple - 3.2KHz/2 = 1.6K or less for crossover frequensy
Crossover could to look as below
R1 C2 or R11 C10 used to damp 4.8K cone breakup
C3 L3 R2 used to damp a very small 1dB peak around 800Hz, so it could be easly avoided.
Those who can, do. Those who can't, teach. Those who can't teach, do research. H.L. Mencken
W18E001 + 27TDFC bookshelves, need design help (sonotube?)Hide this!Advertise here!
WTB: T25CF002 & W18E001 Seas excel ocak Swap Meet 3 2nd July 2009 08:46 PM
Help me pick some new bookshelves 18inch Multi-Way 2 30th April 2008 10:15 AM
FS: Pair of Seas Excel W18E001 midbass units supernet Swap Meet 5 16th November 2007 11:18 PM
Standmount speaker by SS 18W85x5 or Seas W18E001 alspe Multi-Way 8 8th May 2007 03:54 PM
using sonotube in a 2way design? chrisfrost82 Multi-Way 16 11th October 2003 05:02 PM
