PVC pipe enclosures with flat wood baffles - yet another dumb Spasticteapot thread.
2 Attachment(s)
While thinking about ways to avoid woodworking while building speakers, I realized that it would be possible to just cut a 60 degree to 120 degree section out of a speaker, and replace it with a flat sheet of wood. (Probbably birch - not much would be needed.)
You can see what I'm trying to do below. I intend to use this for a simple MTM; there will be a divider seperating off most of the length of the tube. However, the speaker chamber will extend past the wood section a bit I think - this is intentional, and for cosmetic reasons. Because of the big ol' PVC tube section, It makes one wonder: What if it could be made into a really big spiral horn? Either the MTM could be horn-loaded, or a seperate, down-firing woofer could be horn-loaded. http://www3.ocn.ne.jp/~hanbei/eng-whyspiral.html |
Dangit! I never think of anything new. Oh, well. At least I know it will work. |
| All times are GMT. The time now is 07:20 PM. |
vBulletin Optimisation provided by
vB Optimise (Pro) -
vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
