Driver/Xover Replacement on an Old Cabinet
Old 8th January 2003, 07:19 PM   #11
chris ma is offline chris ma  Canada
chris ma's Avatar
Thanks Dave,
But I need to know the range of values of the caps normally used in crossover, like 100uf 50V mono or polarised etc.
Any hint?
Chris
Old 8th January 2003, 08:13 PM   #12
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
Any hint?
To get a ballpark you need to know the nominal impedance of your speaker and the neighborhood of where you want to XO.
a 2 uF cap into a nominal 8 ohms gives an XO of 10kHz. Making it 2x as big moves the XO to 5 kHz, halving it moves it to 20k.
If you have a 4 ohm T, double the cap value, if a 16 ohm T halve them.
Typically the higher the voltage the better the cap sounds, but 50V is probably a reasonable rating for most situations (althou i have seen many a 5V cap on vintage stuff)
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Driver/Xover Replacement on an Old CabinetHide this!Advertise here!
need help xover and polarity of driver hyl2369 Multi-Way 5 25th May 2005 03:27 PM
Removing Zobel network from mid driver xover andy2 Multi-Way 0 5th March 2005 06:49 AM
Dayton driver breakin? Xover help? Something isnt right. r0lf- Multi-Way 2 22nd August 2004 12:21 AM
Xover and driver selection... snootch Car Audio 2 19th August 2003 11:35 PM
DSP card & proper xover for heathkit 859A speaker cabinet x. onasis Multi-Way 6 22nd April 2003 08:39 PM
Copyright ©1999-2017 diyAudio
