Old 7th January 2007, 02:58 AM   #1
freddi is offline freddi  United States
freddi's Avatar
Default Optimal volumes and drivers for Klams?
I've mainly mucked with regular Karlson aspect coupler and built one sealed test klam with 18"
with lower Qts 18", 3-4 foot vented Karlson seemed about enough for rear chamber and about half that for front chamber.
for non-coaxial, K15 liked Altec 421-8 and 421-LF tone-wise.
Magnetar built a vented klam ("Rosie") whose height was right to stack an open baffle mid/HF unit - IIRC this came in around 200. The rear chamber was tuned to 40Hz but not sure of optimal rear chamber volume - maybe 4-4.5 cubic feet before loading the 15" (?) Also not sure what he did with front chamber in black version #2 (if that was the 2nd version)
slot gap on my sealed 18" klam affected its harmonic structure but did not show much on RTA
what did other coupler builders find out/do to make pretty good playing stuff?
this thing is a "klam" - (from John Karlson's Asymmetric Projector's supposed clam-shape dispersion pattern)
JOhn Sero built a copy of one of Mike's klams - I don't know what one vent was for - here's Sero's page - watch out for music loading :^)
http://www3.sympatico.ca/jsero/
this vented 18K is a regular konfigured karlson-type and seems well behaved with good output without much cone excursion. 1/16" p-p is pretty loud
Cascading volumes on a 5C3 amp bereanbill Tubes / Valves 9 10th April 2009 12:02 AM
Chipamp shorting at high volumes. A Sanchez Chip Amps 27 18th September 2008 01:34 PM
lm3886 and differant volumes kanifee Chip Amps 22 9th July 2008 10:51 PM
Designing enclosure volumes Syncroniq Multi-Way 4 6th June 2008 11:09 AM
Driver for low volumes TechnoMage Subwoofers 15 7th October 2006 10:41 AM
Page generated in 0.06987 seconds (66.06% PHP - 33.94% MySQL) with 11 queries
