Old 6th January 2007, 10:22 PM   #1
Default buzz noise from loud speakers
this is my first post I hope I am in the right place.
My front speakers are driven by a denon poa2800 amp the center and rears ar driven by my yamaha 5890 receiver. when I turn the tv on I get a quiet buzz out of my front speakers only. It does not increase or decrease with volume adjustment. When I turn the tv off the buzz stops I think it is from the cooling fan in the tv. I ran an extension cord from the basement to plug the tv into the buzz is still there when I turn the tv on.
(50' away different circuit)
The denon amp pics up the noise the yamaha 5890 does not?????
Is there some gadget I can plug the tv into to stop the buzz from back feeding into the wall outlet?
My rig
50" LCD sony grand wega
yamaha 5890 reciever (drives center and rears)
nad 521bee cd player
Denon poa 2800 (drives front speakers)
paradigm monitor11 fronts
paradigm cc370 center
paradigm adp370 rears
seismic 12 sub
monster 2100 power bar
Thanks for the help
Old 7th January 2007, 04:47 AM   #2
Send a message via AIM to ocool_15 Send a message via Yahoo to ocool_15
Since it doesn't increase with volume it isnt a being fed into the amp input.
Seems odd you pick that up through the amplifer power supply but the first thing I would try is a filter on the fan itself.
Basically make a low pass crossover on the leads going into the fan. It will likely be 12V and I wouldn't bother with anything expensive. A filter consisting of a inductor and cap in series corresponding to the frequency of the fan(converted from rpm) would likely also work. That would be placed in parrallel with the fan.
There may be other solutions but that seems easy enough.
Old 7th January 2007, 05:24 AM   #3
Send a message via AIM to Spasticteapot
I'd just get a surge protector. They often have inductors to isolate RF.
Old 7th January 2007, 06:03 AM   #4
If the denon is earthed, the tv not and yamaha not - then it could be a ground loop problem. (However - ground loop hum often varies with volume).
A simple test is to run a grounding cable from your TV chassis to ground.
If you suspect the TV fan - can you temporarily disconnect your TV fan to see if it stops?
How close together are the components - could it be some sort of EM interference?
David.
Old 7th January 2007, 04:22 PM   #5
Maybe the rear speakers are shielded, and the fronts are not?
Old 7th January 2007, 04:24 PM   #6
Ooops.
Isn't shielding designed to stop interference being produced by the loudspeakers?
Old 7th January 2007, 04:33 PM   #7
David.
I grounded ererything the buzz is still there.
I disconnected the fan in the tv the buzz is still there, so it must be something else in the tv
Old 7th January 2007, 04:36 PM   #8
Netlist is offline Netlist  Belgium
Netlist's Avatar
As a simple test, disconnect the TV and give your system another source, e.g. a CD-player. See if the buzz is still there.
/Hugo
Old 7th January 2007, 04:37 PM   #9
pinkmouse's Avatar
And does the Denon buzz with no input at all?
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 7th January 2007, 07:19 PM   #10
Default tv makes it buzz
The only time I get the buzz is when the tv is on.
If I shut the tv off, the buzz goes away...........
It does not buzz from the cd player, dishnet reciever,direct tv receiver, dvd recorder or dvd player.
Assistance in diagnosing Hum/Buzz/Noise xenithon Digital Line Level 37 24th January 2009 07:39 PM
LM3886 Very Loud Buzz colindj69 Chip Amps 3 2nd September 2008 08:26 AM
Can Someone solve my buzz/Hum noise from turntable FSHZ:42 Everything Else 3 23rd March 2008 11:51 AM
Loud buzz and hum from one monoblock!!! victor1 Tubes / Valves 5 12th June 2006 06:32 PM
Car audio amp, LOUD buzz. what is wrong? silentblackhat Chip Amps 2 12th April 2006 06:49 AM
Page generated in 0.12161 seconds (84.20% PHP - 15.80% MySQL) with 10 queries
