#11 |
I am using a pair of MDT-33 tweeters in my L&R speakers which are MTMs with 1st order series xovers. I chose the Morels because they are very robust and have a low Fs, qualities necessary for a series 2500 hz 1st order xover in a dynamic and often loud HT environment.
The L&R speakers are 28" away from the 27" Sony TV and no effects are noted from their magnetic field. My center channel MTM uses a pair of shielded M-130s from GR Research with a Morel MDS 37 tweeter which is, again, robust, with a low Fs. All in all, I would say go for it on your tweeters. I selected series xovers for simplicity and all 3 speakers use very similar xovers to make their phase shifts around the xover point as much the same as possible to maintain the 3-D illusion of surround sound. |
#12 |
Thanks Dick,
I now feel confident that a first order at 5.2 kHz will be fine for the HT environment with that driver. This is assuming a parallel filter. Tell me, does the series filter attenuate the out of pass band frequencies at a higher rate than the parallel network. |
#13 |
1st order series xovers will attenuate more than 6db/oct, depending on the circuit's Zeta. Go here to read about them:
http://www.partsexpress.com/resource...er/primer.html Also, here is a list of many fine articles about series xovers: http://users.tpg.com.au/users/gradds...oss-overs1.htm Many claim a series xover will hold phase of the two drivers more in step with each other through the xover region than parallel xovers. I find series xovers of the L&R&C speakers to help with the 3-D sense of space as I make all 3 of mine identical. The spreadsheet available at Andy's site (above) is very helpful and is what I used to build my xovers, before tweaking them slightly. But, proper selection of drivers is vital. |
| FS: Morel, SS, PHL | pplu | Swap Meet | 0 | 10th February 2009 05:00 PM |
| Morel CAV-938, anybody uses them? | trummis | Multi-Way | 0 | 5th January 2009 11:13 PM |
| Morel Mw 267 | AuroraB | Multi-Way | 5 | 20th November 2006 02:35 AM |
| Morel HU9.1 ? | Eton | Multi-Way | 3 | 27th April 2006 06:22 AM |
| WTB --- Morel MDT-29 | coffin | Swap Meet | 0 | 5th August 2004 03:12 AM |
| Page generated in 0.09411 seconds (64.58% PHP - 35.42% MySQL) with 10 queries |
