Old 6th January 2007, 04:30 PM   #1
Default Effect of enclosure volume deviation on vent tuning?
Hi everyone,
I have a Peerless 850146 driver in a 70.3 L sealed box, but I want to change it into a vented enclosure, if possible.
The problem is that the box is a bit too small for a SBB4 alignment. According to the design charts in Dickason, the volume needs to be 78.3 L (Qts = .35, alpha is 1.84 assuming QL of 7 from the design chart, Vas = 144 L).
So my questions are: what would be the effect of just using the slightly smaller volume, assuming I calculated vent length based on the actual enclosure volume? Would it be disastrous? Or alternatively, is there any way that I can artificially increase the box volume, or are there other design tweaks that would be helpful in this situation? (I know that for a sealed box, adding stuffing increases the effective volume but I don't think the effect is the same with a vented box). Any help or suggestions would be much appreciated.
Thanks everyone
Old 6th January 2007, 05:02 PM   #2
Ron E is offline Ron E  United States
Ron E's Avatar
the ~10% volume difference doesn't matter much - the vent output will drop this much: dB=20*log10(70/78)
Just do it.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan
Old 7th January 2007, 10:18 AM   #3
Geoff H is offline Geoff H  Australia
As Ron says, just do it.
The smaller volume will increase the res freq of the enclosure. You have lowered it back by adjusting the port length. The result is you will be somewhere between two alignments.
You will still get the lift in the bass, with a faster roll off, compared to sealed. If it gets lumpy, you can dampen the port, or block it up again.
Geoff.
Help with tuning a speaker enclosure retroman Multi-Way 9 17th May 2009 11:36 PM
Port close to the wall--effect on tuning? diesel_88 Multi-Way 3 26th April 2008 10:57 PM
vent tuning - interesting article skogs Subwoofers 6 10th February 2007 12:49 PM
Vent volume REALFLEO Multi-Way 3 30th January 2007 02:49 AM
Tuning an Enclosure squidbait Multi-Way 14 15th January 2004 01:15 AM
Page generated in 0.07494 seconds (70.38% PHP - 29.62% MySQL) with 10 queries
