Hello Everyone-
Got a question for you all. I have been reviewing Zaph's Audaz Mini project. http://www.zaphaudio.com/audio-speaker14.html In his description, he states the design has full baffle step compensation and should not be on a shelf or in a bookcase (they need stands). Reviewing the crossover, I do not see any baffle step compensation in the crossover, am I missing something? With 6.5" wide baffles, the raise should start @ 270 Hz, have an F3 of 730 Hz and be at full magnitude at 4,339 Hz. Crossover point is around 3300 Hz. The woofer section of the crossover has a 3rd order low-pass. How is the baffle step accorded for?
Audio DIY Page FOLLOWMY529.COM - Subscribe and follow the performance of my daughter's 529 College Saving Account. |
#2 |
From what I know you won't see seperate baffle step components. Baffle step compensation is integrated in to the woofer crossover. Zaph doesn't have a filter transfer function graph for this particular project but if you look at some of his others such as the Seas L18/27TBFCG you wil see that the low pass filter transfer function shows an initial shallow slope to provide baffle step compensation before leveling off then starting the actual crossover slope.
Hope this helps, Jason |
| Baffle step Question for unusual enclosure | REM | Multi-Way | 4 | 18th August 2007 07:31 PM |
| Audax Mini Zaph meets up with MJK | jackinnj | Multi-Way | 0 | 8th July 2006 02:00 AM |
| Baffle Step question | mazeroth | Multi-Way | 12 | 24th January 2006 10:45 PM |
| baffle step basic question | kneadle | Multi-Way | 11 | 18th July 2004 09:50 PM |
| question about building crossover with baffle step | Jim85IROC | Multi-Way | 1 | 21st April 2004 03:45 PM |
| Page generated in 0.07541 seconds (67.18% PHP - 32.82% MySQL) with 10 queries |
