Hi all, I am pretty new to this but I have built a ported box with a hartley dome tweeter, eton hex mid and 6.5" hartley woofer. I would like to plug the port and add something, like 1 hartley 10" per side or one 24" hartley. Any thoughts on adding 10's vs a 24?
My local shop leans toward adding the 24", I am leaning to the 10's. Of course they have been building speakers and electronics for thirty years and my first project turned out so good I was amazed. Thanks Also any thoughts about a passive vs active crossover? |
#2 |
What size is the box? Adding more drivers requires more volume in the box for it to work properly.
If you built an active xover you could boost the low frequencies and get more out of a smaller box. |
#3 |
Speakerholic
As Tenson mentioned, you don't just go adding a woofer to an existing box. I would leave well enough alone and use a separate woofer with a plate amp. How large is your room? That will determine how large of a woofer to use. |
#4 |
If I was going to keep all the drivers in one box I would have to build a new one. There isn't room to add anything else. The room right now is 10x16. I have a hafler amp that i was planning to use for either woofer plans. I was planning on a box for the 10's at about 8 cu ft. For the 24 hartlery has a box they use with no back that is 30x30x20. It could be a table also. Thanks guys
Happy boxing day! |
#5 |
Speakerholic
You may or may not wish to plug the ports but it may help if you put a cap on the mains to cut off a little of the low end. This will help the power handling and reduce driver interaction. ie: you don't really want two different drivers reproducing the same frequencies.
#6 |
It has been recommended to me to use at least a 15" like a Dayton becase that size would be the right proportion for what i already have.
#7 |
Speakerholic
A 15" is more than enough for a room that size.
#8 |
Thanks Cal i probably will plug the ports, that's one of the things I don't care for now that boom from the port. I am aiming to have it be much tighter.
#9 |
Sounds like the 24" is intended as dipole with EQ
that will give you thight bassThe shop could maybe offer a demonstration, now its lokal What does the 24" cost |
#10 |
24" hartley is around 1150. They also make an 18" it's about 60 less. Then to the 10 at about 600.
| Adding an amp | GlennDrodge | Solid State | 2 | 13th August 2009 05:16 AM |
| adding aux's | bodaddy | Instruments and Amps | 10 | 22nd May 2008 05:40 PM |
| adding second HDD to PC | AndrewT | Everything Else | 80 | 5th December 2007 01:38 PM |
| Low Qts drivers : Adding mass | 316a | Multi-Way | 20 | 4th May 2006 02:27 PM |
| Page generated in 0.10245 seconds (75.94% PHP - 24.06% MySQL) with 10 queries |
