Hello everyone,
I have built a Death of Zen amp. I use it with B&W DM14 speakers, of which I replaced the internal wiring with 2x2.5mm2 OFC. It sounds very detailed and revealing, but also too bright, as if the tonal balance is off. As a result, some music sounds annoying in the long run. Also, the speakers aren't very efficient - they're rated at 86dB/watt, and their low-end response could be better. So, I'm looking for new speakers. Because I have a wide musical taste, I want them to sound neutral. Furthermore, I would like an improvement in the low bass response. Finally, I would prefer a more efficient speaker - I think around 90dB/watt would be ok. I haven't decided on a final budget yet, but it's probably around 600 euros per speaker (in part, depending on the quality I can get for that money). So far, my shortlist contains 3 speakers: - Epos M15.2 (said to be neutral sounding, with improved bass response over the M15, not very efficient at 88dB/watt though) - Monitor Audio Silver RS6 (more efficient at 91dB/watt, should also go a bit lower in the bass) - Kef IQ7 (also pretty efficient, but a bit flat-sounding according to some) So any other suggestions before I start auditioning them? |
#2 |
Speakerholic
Have you considered building your own? This is a DIY site after all.
#3 |
I actually auditioned a few DIY speakers at a DIY speaker store, and my first impression was good. But I'm not sure I want to take the risk of building them myself. I've heard that speaker cabinet construction is a critical part in the overall result. If I don't do it exactly right, I'm afraid it won't sound as good as it could have. As such, I'm not sure DIY would be worth the effort here.
#4 | |
Official Court Jester
you can arrange that local carpenter make cabs for you even in that case you'll spend less money,or you can have better spks for given value choice is yours making cabs from finished plans is piece of cake
my Papa is smarter than your Nelson ! tnx to |
#5 |
An update:
I might be able to buy used Tannoy 615 Mk1 speakers. These are the biggest in the Tannoy "Sixes" series. The efficiency is 92dB/watt, so that's very good. Frequency response is said to be 45-30000 hz (-3dB), so that also looks promising. Maybe someone here has experience with those speakers and DoZ-like amps? |
#6 | |
Hi, Seems a good choice to me. You could also bi-amp with the DoZ for the mid/treble. /sreten.
#7 |
#8 |
I'm going to audition them next monday
#9 |
By the way, what would be a reasonable price for these speakers (they're Mk1's), assuming that they are in good condition?
#10 |
I have spent many trips with my DOZ to stores and finaly found the right speakers for me.
Triangle Celuis ESW. 30,000 TO 40 and sensitivity at 92db. T |
| help choosing speakers again >90dB wanted | kmj | Multi-Way | 17 | 10th February 2007 03:14 PM |
| DEATH by UPS | exurbia | Planars & Exotics | 10 | 4th June 2006 12:29 PM |
| speakers choosing | ulolin | Car Audio | 4 | 19th November 2005 11:27 PM |
| Help on choosing an old Goodmans speakers | beta_sound | Multi-Way | 5 | 16th May 2004 08:58 PM |
| Choosing amplifier for PC speakers | soundNERD | Chip Amps | 9 | 27th September 2003 02:10 AM |
| Page generated in 0.21437 seconds (43.72% PHP - 56.28% MySQL) with 10 queries |
