My wacky budget n00bie 3-way thread. Abuse wanted!
Old 4th January 2007, 10:11 PM   #1
Spasticteapot is offline Spasticteapot  United States
Send a message via AIM to Spasticteapot
Default My wacky budget n00bie 3-way thread. Abuse wanted!
Having recently seen a bunch of threads on the subject, I figured I'd throw out my latest foolish thought - a cheap open-baffle mid / TL woofer hybrid speaker.
The configuration is nothing fancy - it's a MTMW, with the mids used open-baffle, the woofer in a transmission line, and the tweeter mounted wherever. (Yay, dome tweeters!)
You can see something vaugely similar to my idea here:
http://myweb.tiscali.co.uk/nuukspot/...speakers5.html
Anyway, I was thinking of using the following drivers:
Tweeter: These will only be used above 16khz to reinforce the treble of the B3Ss, which I've heard may be necessary - if not, I'm not spending much on them anyway.
The Dayton N20FB is $5, and works nicely up to 20khz. It's not perfect, but it's not doing very much.
http://www.partsexpress.com/pe/showd...number=275-035
Midrange:
The Hi-Vi B3S works well OB, and it's cheap. It also looks very snazzy. The SPL sucks, though - that's why I'm using two.
http://www.madisound.com/cgi-bin/ind...6.385&pid=1831
Woofer:
The woofer will be crossed over around 250hz. I honestly don't know what to use, but the W20RC38 8" silver-flute woofer is pretty decent, and reasonably priced.
http://www.madisound.com/cgi-bin/ind...25640&pid=1081
The biggest complaint I've heard is that it "needs a midrange". No problem on this one.
Seeing as how I can't even figure out how to use WinISD, I figure I'm better off just gleaning what I can while people giggle. (Sue me - I'm learning Linux on my own time, and it's not easy.)
I doubt I can afford to build this project, but I'd like to see what others think.
Old 5th January 2007, 12:17 AM   #2
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
If you're going (nearly) full range with the B3S, you'd be better off going TMMW to avoid beaming problems with the mids being so far apart to get the tweeter in.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
My wacky budget n00bie 3-way thread. Abuse wanted!Hide this!Advertise here!
Tony Gee's Low Budget Speaker - Build Thread mrevie Multi-Way 27 18th April 2011 11:40 PM
Reporting an abuse caused Thread Close? jkeny Everything Else 6 20th April 2008 06:50 AM
High sensitivity(>90db) budget speakers wanted kmj Multi-Way 40 28th April 2005 04:23 AM
n00bie problem maciekish Multi-Way 14 30th December 2002 08:50 AM
Copyright ©1999-2017 diyAudio
