Hi all,
Could you Accuton owners give few details from your drivers? Here is a picture of C2-12: http://www.accuton.com/img/products/...C12-6front.jpg Looks like there is a pretty flat surface below the grill around the surround and inverted dome. But is it really flat? I know those grills are removable and I thought to use them with waveguide but I'd need to know can I install them nicely into one. How much is that dome + surround diameter? (considering waveguide throat diameter). Have you liked your tweeters? Any discription of their sound? What kind of applications you have used them? Crossover loops, frequences... Thanks ! Jussi |
#2 |
Hi Jussie,
For more details on the accuton C^2 12, you can have a look here: http://www.hifivoice.com/audio/miles...surements.html and http://www.hifivoice.com/audio/miles...ffraction.html I've also a picture of a broken C^2 12 (luckily not mine) with its grill removed. The sound is crispy, direct and transparant. But it requires steep filtering to stay away from breakup, needs some felt dampening, and it is difficult to get "airy" sound out of it. Marc |
#3 | |
Stay away from the breakup? You mean that ultrasonic breakup or does it have other problems as well? Have you tried Seas standard line aluminiums, how do they perform compared to Accuton? Thanks. Jussi |
#4 | |||
Also see http://www.accuton.de/img/products/c...2/C12-6DRW.pdf Quote:
Marc |
#5 | |
Thanks. Jussi |
#6 |
I suspect this will give you all sizes that you want to know.
Marc |
#7 | |
Jussi |
| similar to SKA | djk | Solid State | 6 | 7th June 2007 03:28 PM |
| looking for similar FET | Ahmad_tbp | Solid State | 5 | 6th May 2006 09:26 PM |
| Tune Dem or similar anyone? | Jussi | Everything Else | 0 | 3rd January 2006 08:59 AM |
| Who's using trueRTA? or something similar? | Ken L | Multi-Way | 6 | 15th February 2004 04:35 PM |
| Page generated in 0.11542 seconds (79.51% PHP - 20.49% MySQL) with 11 queries |
