I have noticed that different sources are giving different T/S parameters values for for this driver. Which ones should I believe? What kind of values you have measured? I do not have proper signal generator, so I can not measure these by myself
![]() VAS 28 liters; 16 liters; 11.8 liters; 28 liters Fs 30 Hz; 36 Hz; 44.26 Hz; 30 Hz Qts 0.24; 0.4; 0.54; 0.35; Qes 0.29; 0.42; 0.59; 0.38; Qms 4.9; 7.61; 5.8; 4.9; There is specially big difference with Qts and Qes. Currently I have a 25 l vented box. If I use Tymphany's values, size of box should be about 10 liters, since Qts is so much lower. NorthCreek is proposing 16 - 20 liters vented box. According to Tymphany EBP = Fs/Qes is 103 which is over 100 and this means that I should consider a BR box. When I use other values EBP is about 75, and this means that I should consider a closed box. |
#2 |
>I do not have proper signal generator, so I can not measure >these by myself
Proper Signal Generator = PC + Sound Card + Cheap Soft (like NCH Tone Generator) |
#3 |
Hobby Hifi 4/2003 measured these:
Fs 29 Hz - Qms 4.8 - Qes 0.33 - Qts 0.31 - Vas 34 l . Box recommended: 21 l tuned to 30 Hz BRport 40 mm diameter 170 mm length. Look for A4 Monitor (Dutch) and Troels Gravesen's W1500/97. As far as I know most people prefer about 10 l volume. |
#4 |
Thanks Mingo,
I have also noticed that most of the people have used ~10 l cabinets for this driver. I did WinISD simulation for the cabinet recommended by Hobby Hifi. Result was quite good. I think that I need to consider to put about 4 - 5 liters of sand to my 25 l cabinets. |
| Building Transmission Line for SS 15W8530K00 | LifeIsMusic | Multi-Way | 15 | 4th April 2010 07:33 AM |
| WTT for 15W8530K00 and/or XT25TG | thadman | Swap Meet | 0 | 31st January 2008 11:26 PM |
| Scan Speak 15W8530K00 | fireman1 | Multi-Way | 7 | 28th April 2007 04:06 PM |
| Scan-speak 15w8530k00 or SEAS L15RLY/P... | gcm908 | Multi-Way | 0 | 16th January 2006 07:55 PM |
| Page generated in 0.07714 seconds (69.55% PHP - 30.45% MySQL) with 10 queries |
