I am searching for a box for my JBL 2215 15" below 300hz for a 4 way design. but i don't have any information about this speaker (qts, qes,...). just fs 20hz. the filter for this design are active with dcx 2496.
what about SB with 160 liters ? for the rest low mid with tractrix horn (rcf L12P110K) upper mid with JBL2441 and for the high a fostex T900A. sorry for my poor english and happy new year. |
#2 |
Parameters for 2215A (2215H is identical) are:
fs: 20 Hz Re: 5,7 ohm Qms: 5,5 Qes: 0,22 Qts: 0,212 Sd: 900 cm2 Vas: 736 l Xmax: 4,1 mm Le: 1 mH Pe: 100W SPL @ 1W 1 m: 96,2 dB The 2215 would work well in a vented box of 90 liters tuned to about 38 Hz. Port dia 11 cm, port length 13 cm. Good luck & happy building. PS: T/S parameters for most of JBL transducers is here: http://www.jblproservice.com/pdf/Thi...arameters.pdf. EspenE |
#3 |
I like the look of around 180L tuned to 28Hz for good in-room bass. |
#4 |
This will of course also be good - somewhat at the expense of power handling.
It all depends on room, amplifier, max SPL, etc. EspenE |
#5 |
OK a lot of thanks for the reply.
| Collated Design Criteria/dimensions for Ariel ML-TL Design | talsius | Full Range | 1 | 13th October 2011 05:28 AM |
| Wilson Watt Puppy Clone Design - Design Review Please | soundengine355 | Multi-Way | 8 | 15th August 2008 02:07 PM |
| Page generated in 0.07991 seconds (72.01% PHP - 27.99% MySQL) with 10 queries |
