electronic crossover modification
WARNING ....not an electronics expert.. not even an electronics amateur...
but I just built an electronic subwoofer crossover from a kit, I simply soldered and prayed a lot :D It has a volume gain pot but it has no cut-off frequency pot, it has a DPDT that switches from 50 or 70 hz. Is the default 50 or 70 hz setting based on the values of the resistors and capacitors ? Does the two IC thats built into the kit play a role in the cut-off frequency. My goal is to change these to 30 and 40 hz, as I can still localize the position of the sub on the 50 hz setting.
I know i need to post the schema, but as i have not taken a photo of the schema as of the moment. If the 50/70 hz cut-off is based on the IC then there is no need to post the schema as this would not be possible to change given my expertise.. thanks
Re: Re: electronic crossover modification
good so it can be modified
pinkmouse said:
Most likely, yes.
That sounds more like a problem with the slope, it may be too gradual and letting too much high frequency through.
What if I daisy chain two Electronic crossover ? its an 18 db per octave crossover..will this now be an 36 db per octave crossover ?
is this good or bad ?
