Old 1st January 2007, 04:20 PM   #1
Default vifa plw 18 342/8
I am going to build a two way speaker using vifa (probably seas) drivers. Vifa plw 18 342/8 seems to be a good dirver, but I have not found any information on it. Does anyone have experience with this driver?
http://www.vifa.de/produkte/DBPLW184.pdf
I have not found this driver on tymphany's homepage, probably it is available only in germany.
Old 3rd January 2007, 11:28 AM   #2
After some search on the web i have found that the vifa plw 18 342/8 and the vifa M18WO-09-08 are the same
http://www.tymphany.com/datasheet/printview.php?id=269
Should I use it in a two way or the PL18 probably the Seas CA18 is better? Is there a better sound/value rate 18 cm driver?
Little help needed - Vifa MG18 + Vifa DX25 - 2.5way guitvinny Multi-Way 12 10th May 2009 10:18 PM
Vifa P17SJ and Vifa D27TG Large Bookshelf MTM rwo Multi-Way 7 24th February 2008 04:47 PM
Page generated in 0.07609 seconds (75.40% PHP - 24.60% MySQL) with 10 queries
