diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Multi-Way (http://www.diyaudio.com/forums/multi-way/)
-   -   Reasonably priced 15" PA woofers in Canada? (http://www.diyaudio.com/forums/multi-way/93222-reasonably-priced-15-pa-woofers-canada.html)
Cal Weldon 1st January 2007 01:21 AM
I need four and I was looking at these no names:
http://cgi.ebay.com/15-TS2-HIGH-EFFI...QQcmdZViewItem
Anything comparable north of the border? Around $100 each? SQ not an issue. Nice big motor preferred. :smash:
maxro 1st January 2007 02:19 AM
Hi Cal,
You might try here. Their 15" is only 90dB, but the 18" is 93.4dB (at 4ohms, I assume) and actually cheaper than the 15"
Cal Weldon 1st January 2007 02:56 AM
Hi Max,
Thanks for the link but I didn't see any PA woofers in there, just those "subs"
These have to have an accordian surround and low X-max as they are rear mounted in a horn. These are to replace the Pyramid auto woofers I have in the big 210 cabinets. As it sits now, the foam surrounds contact the baffle under "party" conditions.
maxro 1st January 2007 03:39 AM
Sorry, my bad. I didin't realise your need for progressive suspension and was just going off similar price and sensitivity.
punkrokr1701 1st January 2007 06:09 AM
hey cal, i see you are looking some 15" woofers, :devilr: my specailty :rolleyes: Well i havent looked at the shipping rates lately to Canada at Parts Express but it can't be much more than what i payed to have my titanic MkIII shipped here, anyways thisDayton 15" woofer looks nice enough but it seems to take on more like a subwooferwith a SPL of 89 and low QES and QTS and you want low Xmax anyways seeming as your mounting it in a horn so scratch that. Well umm i think the Selenium 15PW3 15" should do the trick low xmax, reasonly loud ( 98 db/1 watt/ 1 meter ), the magnet could be a little bigger though, o well it's only $80 and with combined shipping shouldnt be to bad. If you dont get one I am and being that your useing them in horns just though id update you on the BBBIB speakers by saying that I've ordered the drivers. SO yeh i thnk that should do if not well thats a few other drivers at partds express that will do good for you.
Cal Weldon 1st January 2007 06:17 AM
Hi Punkr,
Thanks for chiming in. You're right the Dayton won't cut it as I need an accordian surround not a half roll.
I want to order from Canada rather than south of the border if that's possible. If I am ordering from PE I would get the Selenium WPU 1507 QCF to match the two I have now. (in my A7's that we talked about before) These are for the dual 15, A4 cabinets.
I am tired of paying for the exchange, GST and delivery/brokerage fees. It doubles the cost.
I don't need super high quality just something for the 50 to 125Hz range.
johninCR 1st January 2007 07:34 AM
Across the border but MusicSupplyCenter.com has great deals. I picked up 6 of their Warrior 15's for $20/ea. I had to do a little glue surgery on 2, but they're surprisingly good otherwise. The Knights appear to be a significant step better. Cast frame 15's for $65/ea. Check here:
http://www.musicsupplycenter.com/Pro...Show=TechSpecs
chainenoble 1st January 2007 10:56 AM
eh cal, have you looked at these guys,
http://www.mcbrideloudspeaker.com/
they use to have an catalog with prices that you could download,but i donīt see it anywhere now.
NVMDSTEvil 1st January 2007 11:25 AM
dang... A while ago I had a line on 4x Cerwin Vega 158's that probably would have done the job.
Cal Weldon 2nd January 2007 08:57 PM
Yes I buy from them a few times a year.
[i]they use to have an catalog with prices that you could download, but i donīt see it anywhere now. [/B]
Luckily I downloaded it before they removed it from the site. Only problem is it an old catalogue and much of what's in it is no longer available.
Resources saved on this page: MySQL 18.75%
