'LGT' Construction Diary
Old 5th June 2007, 12:03 AM   #901
ShinOBIWAN is offline ShinOBIWAN  United Kingdom
ShinOBIWAN's Avatar
Heh, I like
So you decided to go with these in a 3-way then or are they sub use only?
The more you know who you are and what you want, the less things will ever be the same.
Old 5th June 2007, 04:16 PM   #902
sploo is offline sploo  United Kingdom
Originally posted by ShinOBIWAN
Heh, I like
So do I, and thanks once again for the heads up.
Honestly - dunno. I've come to the (rather obvious) conclusion that if I want to learn about this speaker design lark, I really need to get around to buying some drivers.
I have a vague idea of getting a tweeter and midbass (looking at Zaph's site for response and distortion data) and maybe making a simple two-way, then extending it with one or two XLS10s.
I had a brief chat with Siegfried Linkwitz, who indicated that if you're going the boxed speaker route, then stereo sealed subs would be his preference for the bottom end (i.e. two sealed units, rather than one, or vented/ported unit[s]).
I'd like to put two XLS10s in one box, but it's occurred to me that the minimum impedance is probably going to get a little low, plus I need to consider getting an amp for them, plus a crossover, plus working out a suitable box size, plus looking into a Linkwitz transform, plus... *sound of head exploding*
Old 5th June 2007, 04:42 PM   #903
ppcblaster is offline ppcblaster  United States
Default pm
Originally posted by pinkmouse
I suspect you'll be using that compound mitre spreadsheet we put together quite frequently.
Where can I find the compound mitre spreadsheet?
Can someone point me towards some links so I can learn
what f3, is all about? I need to start at the noob level..Thanks
Old 5th June 2007, 05:58 PM   #904
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
David Weems books are a good introduction for beginners.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 5th June 2007, 05:59 PM   #905
nirmal is offline nirmal  United Kingdom
Default Re: pm
Here.
Old 5th June 2007, 06:05 PM   #906
Thank You
Old 6th June 2007, 11:59 AM   #907
Yea, I have his book.
I've been spending my time researching box construction, and learning to use a CNC machine I bought, so hadn't read it in a while. I have also been reading a lot of online stuff about speaker design though, so it was good to flick through it last night and realise I'm beginning to understand a lot more of what he's talking about.
Need to get this box painting thing sorted first though!
Old 6th June 2007, 12:22 PM   #908
Did it Himself
He does take a simplistic textbook approach, but for getting to grips with the world of box types and parameters etc it's a good easy start without getting confusing.
Old 6th June 2007, 05:51 PM   #909
thylantyr is offline thylantyr  United States
Shin,
ATC in car.
http://forum.elitecaraudio.com/showt...hreadid=142659
Old 6th June 2007, 05:54 PM   #910
ShinOBIWAN's Avatar
Originally posted by thylantyr
Shin,
ATC in car.
That's the way it should be done. None of this Pioneer or Alpine tat.
'LGT' Construction DiaryHide this!Advertise here!
