Old 20th January 2007, 11:57 PM   #61
pinkmouse's Avatar
Not going to try the Audax HM100Z0s then Ant?
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 21st January 2007, 12:05 AM   #62
tinitus is offline tinitus  Europe
At 93db I would consider a single mid with accuton tweeter, and still use double 10" woofer, just thought but you have to consider BSC
Old 21st January 2007, 01:35 AM   #63
ShinOBIWAN's Avatar
But I've set a driver budget and it just wouldn't feel right not to blow it all.
Joking aside, I've already done something a little similar to what your suggesting with the Perceives ie. fairly efficient WMT. I'm stuck on the WMTMW idea now. Cheers for the suggestion though.
Old 21st January 2007, 01:39 AM   #64
ShinOBIWAN's Avatar
Still haven't used these yet. It can't be anything less than a cracking mid driver after all the positives I've heard but I don't think it would run down to 200hz very well. I do see its very efficient for a 4" driver though.
I'll give them a try sooner or later, just got to find the right project for them... and the time.
Old 21st January 2007, 04:14 PM   #65
ShinOBIWAN's Avatar
Any opinions on this shortlist of 12" bass drivers?
Volt RV3143
Beyma LX60
B&C 12TBX100
B&C 12TBX100
I also looked at the PHL 4530 and the Precision Devices 12" range but the baffle recess shape is an instant turn off so I think those will be given a miss.
Another interesting one is the P. Audio SD12. Never really heard much about these but the seem to tick most of boxes with triple shorting rings, FEA motor and spider/surround. Looks like plenty of thought went into them.
I'm ideally looking for one to cover the 35-200hz range with nice flat extension out past that point. This is virtually a given with pro-drivers since most are nicely extended, afterall a 12" in pro territory is often considered a mid driver.
Can't help but feel I've missed some of the really good ones though. Any other suggestions or thoughts?
Cheers
Ant
Old 21st January 2007, 05:00 PM   #66
taloyd is offline taloyd  United States
Default another choice
Hello,
Don't recall if you're going active or not, but if you are (which makes efficiency nearly a non-issue), I wouldn't discount the Aurasound NS12-513... which has an amazing motor (underhung neodymium), excellent cone, response well past your needs (above and below), and is at least $100 cheaper per driver than your choices. I would imagine it's perfectly competitive, even with the greater-bang-for-your-buck domain of professional drivers...
Also, what about 18Sound?
Driver:
http://www.madisound.com/cgi-bin/ind...27106&pid=2096
PDF spec sheet:
http://www.madisound.com/pdf/aurasound/NS12-513-4A.pdf
Just my two cents...
-tal
Old 21st January 2007, 05:16 PM   #67
I think the problem with effektive PA 12" normally is high Fs and low Qt
Beyma also has a 12" studio bass 12B100-R, but its rather "old" classic
Montana use McCauley - but a bit ugly looking
http://www.mccauleysound.com/compone...iew.cfm?ID=115
or theese might be good
http://www.aer-loudspeakers.com/eng/bass-e.htm
Old 21st January 2007, 05:49 PM   #68
Fostex has announced this new woofer .... but probably hard to get hold of ... but interesting
http://www.fostex.jp/release/FW405N.pdf
UPS .... a big one
Old 22nd January 2007, 11:58 AM   #69
Hi Ant,
One more to consider might be the Eighteen Sound 12LW1400. Not too far from the 12TBX100 in specs.
12LW1400 Fs=45, Qts=0.3, Vas=55l, Xmax=8.25mm
No experience with this driver other than recommendations from others about 18 Sounds general build quality
Old 22nd January 2007, 12:58 PM   #70
LineSource's Avatar
http://www.audiocomponents.nl/speake...erence_eng.htm
The Maxima Scan Speak design looks like a simplier effort
Page generated in 0.15039 seconds (76.12% PHP - 23.88% MySQL) with 11 queries
