#451 |
Hello,
I'm following this thread with most interest. I have to say that shinOBIWAN's progress is just fantastic. The reason I was that intersted (besides catching some woodworking and cabinet building tips Now, I was just wondering, why exactly the mid's would be best in a closed box as Mr. ScottG and holdnet seems to report? I always thought that the best advantage of open baffle is not only in bass but midrange too. And another problem, what is the radiation character of an OB compared to a closed box that favours the last one? I am somewhat intrigued mainly reading the last articles on linkwitlab and the older ones on musicandesign which seem to favor actualy a dipole configuration all the way to 22Khz by adding a rear tweeter. Of course dipole character and open baffle are quite diffent as jussi mentioned in the 4-way open baffle thread, but still... I just hope I'm not just threadjacking here with my questions Best regards! |
#452 | |
diyAudio Chief Moderator
To me the most interesting combination to experiment with would be OB bass and cardioid mid-high. |
#453 |
APRE tool 8" + 5" + ribbon WMTMW
300, 2000, 3rd order time aligned baffle offsets |
#454 |
APRE tool 8" + 5" + Dome WMTMW
#455 |
What's running at my house
APRE Tool 3-way 90" ribbon linesource 15" woofer line array, 3" mid, 0.4" tweeter 80Hz, 3200Hz 3rd order |
#456 |
pictures?
#457 |
Thanks for that Linesource, I'm working hard to lessen those problems but not at the expense of subjective quality.
#458 |
Does anyone know what the thickest MDF available is?
Ideally looking 50mm(2") or even better, 75mm(3"). I've seen 36mm but is there anything thicker? |
#459 |
Kind of a weird question but does anyone know if contact cement reacts with 2 part or single part paints?
What I'm going to be doing is veneering over all these problematic joints that were created after cutting the angles in the baffles: ![]() Without the veneer its near impossible to stop them from creeping back through the gloss finish - believe me I have tried! So the plan is cover them up with a plain and stable veneer (0.6mm thick Beech), use contact cement to stick the veneer and then spray over as normal. But the thing that has me worried is will the contact cement react or be broken down by the chemicals in the paint? I hate to do all that work and then find the veneer starts to blemish at a later date. This is the contact cement: http://www.tooled-up.com/Product.asp?PID=2561 I guess the sensible thing to do is a test piece but if I could get a little insight from someone who's tried this then even better. Thanks for any advice! |
#460 |
Contact adhesives certainly react with various oil based finishes. I'd knock up a test piece and try it, that way you know for sure.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
| Page generated in 0.12665 seconds (77.56% PHP - 22.44% MySQL) with 11 queries |
