#1381 |
You have probably covered the topic some other place -
but could you please elaborate on how you control volume in your setup. I would also like to know if you have tried doing your stuff using Vista and especially from Media center. IMHO, The Media Center front end is a big plus when you have your familly using the system also. I like your soundcard, but I think I will go for class D amps to save some enrgy ![]() Thanks
#1382 | |
If you notice I swapped out the larger RAAL for the baby one, the difference is a ribbon length of 14cm vs. 7cm, The little RAAL also now uses the foam deflectors as seen in the larger RAAL's. Alex promises that this now makes the design comparable to a 1" dome disperation in the vertical and a fair bit better in the horizontal. The stand for the center could also be made a couple more inch higher to further bring it inline with the main drivers. Center channel placement is very nearly always compromised but it might just work. From experience the large RAAL in the LGT's is more than acceptable off-axis when the deflectors are used. There's still plenty of HF content even stood up from a couple meters away, the little RAAL should be better. |
#1383 |
cph a decent switching amp will use as much as a linear a/b when sat in idle, the efficiency is greater when running, it's a bit of a red herring.
hoping to pick up some things. |
#1384 | ||
#1385 | ||||
Yes that's right. In simplistic terms; If you imagine the sample rate of the correction filter as its bandwidth, the resolution is determined by the bit precision and the number of samples(taps) within the filter is the length. More taps offer more flexible and accurate correction. Quote:
This is no problem for audio only tasks such as music playback but forget it for movies or any realtime application. In these cases you need minimum phase filtering and again this is possible on the PC so you don't have to start being selective about what your audio system can or cannot do because of latency. Quote:
I'm writing a loudspeaker DSP guide right now that will really break down the steps needed to achieve the things I've been talking about throughout the latter part of this thread and much more besides. It should make it accessible to virtually all interested parties regardless of technical know how. Quote:
There are newer, simpler and better methods now.In my case the computer does everything - its the music server, its the gaming machine, its the movie playback device and a its the loudspeaker DSP and crossover. But the methods used for the latter part of that equation are entirely flexible enough to take external audio and process that. Aside from this you can use programs such as AutoIT to create scripts that accomplish anything you'd do with a mouse and keyboard within the windows environment. So on windows bootup you could load Console set it to activate and load a particular crossover preset and that would be it. To the end user this would appear as a box you turn on, wait a couple of minutes for it to initialise and then from there you play music or whatever. Such is the power of this setup that you can even add an IR with remote as I've done. This then allows you to setup more AutoIT scripts that tie in with the IR software hotkeys. You can then very simply switch between crossover and correction setups as the push of a remote button ie. low latency minimum phase for movies, quality linear phase for music. The limits are endless here. So a streamlined and silent PC box is possible that would operate just as the DEQX or any other standalone hardward would. Of course when you wish to tinker under the hood you'd need to rig up a keyboard, mouse and screen but once set you can forget and still have all the convenience of a modern standard alone device. Its amazing how far it has come even in the couple of years I've been playing with all this. |
#1386 | |
For the volume control I'm attenuating at the source(the PC) for now. But Russ White is designing a flexible remote preamp that is configurable and expandable to allow multiple inputs and outputs. Its an excellent solution for active loudspeakers and/or home theater. |
#1387 | |
#1388 |
#1389 | |
I would say they'd be excellent for inbedded solution or where the user doesn't need maximum flexibility or quality. The feature set is comparable to the DCX2496 ie. min phase filtering with PEQ and software configurable. The added bonus is the EQ automation. Downsides are fixed DAC's, limited flexibility and limited power. Certainly a great answer to some situations but its not comparable to the PC solution. |
#1390 | |
I have done tests with 5.1 setup and linear filters on my 5 year old laptop. With a modest delay on the picture through AC3 filter - and 32 k tap filter length it seems to work pretty well. But who knows? Maybe my laptop is blessed with a very slow graphics processor . There is a correlation between number of correction paths and processing speed, so it may be harder to get full lipsync + full stability on systems that are both multichannel and active. A vital Duo processor should be able to handle the task pretty well though. In any case a no-compromize solution may be trivial to implement pretty soon if it isn't already. All that is required is cpu power and video delay control with a little headroom. A minimum phase solution is of course a good fallback strategy if the linear phase route fails. And it can be made to sound very good too. |
| Page generated in 0.19263 seconds (80.57% PHP - 19.43% MySQL) with 11 queries |
