Old 6th September 2007, 07:14 PM   #1271
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
450Hz 3dB per octave halving on your box, IMHO.
Old 6th September 2007, 07:17 PM   #1272
ShinOBIWAN's Avatar
How can that be? The baffles just aren't wide enough. Please explain more.
Old 6th September 2007, 07:24 PM   #1273
Salas's Avatar
The baffles have a height and a sand clock expansion and you have a room too. Your plots show needing moderate BSC from 450Hz to my eye, nothing more. You will swamp the dynamics else, me thinks. Plus 4 are going to be at play and then the power response is going to go heavy. I would shape and use from 350Hz to 3500Hz. Vocal decade bliss.
Old 6th September 2007, 07:52 PM   #1274
pinkmouse's Avatar
I'd guess about 600, but there's not much in it. Wack lots of smoothing on the curve, it helps define trends like BS a lot easier.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 6th September 2007, 07:54 PM   #1275
ShinOBIWAN's Avatar
Thanks chaps I'll update and post the results to see if it looks OK.
Old 6th September 2007, 08:08 PM   #1276
ShinOBIWAN's Avatar
White is with the suggested baffle step and purple is without. Looks better. Thanks for that. Don't pay too much attention below 200hz because its not accurate.
Old 6th September 2007, 08:36 PM   #1277
Salas's Avatar
Cool.
Old 6th September 2007, 09:03 PM   #1278
Did it Himself
richie00boy's Avatar
How do you do them plots? Vikash mic + pre and some software?
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 6th September 2007, 11:17 PM   #1279
ShinOBIWAN's Avatar
Yes, that's pretty much it. You can either build your own mic and preamp or buy something cheap like the Behringer ECM8000 and MIC100 which should run to about £70-80. Plug the mic into the pre and the pre into your line in on the PC soundcard. Then its upto you regarding software, my favourite is ARTA and this was used to produce the plots I posted recently.
Old 7th September 2007, 12:12 AM   #1280
wigginjs's Avatar
Shin:
You take your measurements indoors right? Do you do anything special with the placement of your speaker and microphone before measuring or do you just rely on the gating to clean everything up? About how long is your gate?
The Four Chairs
DIY Home Theater
Page generated in 0.09745 seconds (76.08% PHP - 23.92% MySQL) with 11 queries
